Revo w/ OS18TM wont start
OK. So I was having problems starting the Revo and decided to replace the OWB and seem to start up within 30 seconds with is about 10 minutes faster then before so that was great. Now, after letting it sit for a few days, the engine wont turn over at all. I called my LHS and they said perhaps the gears in the EZ Starter are loose and not grabbing. So I took that apart and everything is good the way it should but the engine is still not turning. The EZ Starter spins when the button is pressed though. So I did some reading and other people have indicated they have had issues with their EZ Starters so I decided to buy a pull start and install that. Still the engine will not turn over. Its as if somethings not catching. When I replaced the OWB, I turned it a few times and the piston would move up and down. Now, sometimes when I turn the OWB, the piston doesnt seem to move like I think it should.
At this point Im ready to throw the stuipid thing out the window. Any help would be greatly appreciated. |
RE: Revo w/ OS18TM wont start
Crank pin sheared or connecting rod broke??? Just guessing here of course.
take out your glow plug and see if turns over... also, check to see that you placed the OWB in the proper way.
With a pull start you should be able to feel the compression as the piston reaches TDC(Top dead center) if you're not feeling anything there's something wrong.(This is assuming your one way bearing is working properly.)
ORIGINAL: cujoman take out your glow plug and see if turns over... also, check to see that you placed the OWB in the proper way. ORIGINAL: Th3pwn3r With a pull start you should be able to feel the compression as the piston reaches TDC(Top dead center) if you're not feeling anything there's something wrong.(This is assuming your one way bearing is working properly.) Thanks for the input |
Same thing happend to me and the starter shaft was broken.......Only $8 check out the inside.... take the cooling head and backplate off to see if thre is anything broken
Hopefully there's nothing wrong with the engine internally but it could be a possibility.
ORIGINAL: FISH KILLA Crank pin sheared or connecting rod broke??? Just guessing here of course. The Traxxas part number for the IPS crank shaft is 5219. Does anybody know if this will fit the OS18TM engine or should I find a specific part number for the OS engine itself? Also, is there just a pin by itself that I can buy instead of the entire crank shaft? Sorry for all the questions. |
