Engine Help
3.3 won't stay running after I remove the glow igniter. I just tried new fuel, new fuel tubing, and have tried my stock exhaust and my Vantage pipe which I have had no problems with in the past and new glow plug and it is at stock settings. When I removed the glow plugs they where pretty wet which is of course not normal. I get it started with no prob. and can rev it and even idle but when I remove the Glow Igniter it dies immediately. Thanks for the help!!
RE: Engine Help
Both Plugs are good that I have tried should I try a hotter plug? I have never had experienced this due to a plug temp though.
RE: Engine Help
ORIGINAL: george3.3 3.3 won't stay running after I remove the glow igniter. I just tried new fuel, new fuel tubing, and have tried my stock exhaust and my Vantage pipe which I have had no problems with in the past and new glow plug and it is at stock settings. When I removed the glow plugs they where pretty wet which is of course not normal. I get it started with no prob. and can rev it and even idle but when I remove the Glow Igniter it dies immediately. Thanks for the help!! The stock settings are your problem. Tune the engine and the dieing will go away. The stock settings are for break-in or as a starting point for tuning. They were never meant to be the normal running settings. |
RE: Engine Help
ORIGINAL: DaveG55 ORIGINAL: george3.3 3.3 won't stay running after I remove the glow igniter. I just tried new fuel, new fuel tubing, and have tried my stock exhaust and my Vantage pipe which I have had no problems with in the past and new glow plug and it is at stock settings. When I removed the glow plugs they where pretty wet which is of course not normal. I get it started with no prob. and can rev it and even idle but when I remove the Glow Igniter it dies immediately. Thanks for the help!! The stock settings are your problem. Tune the engine and the dieing will go away. The stock settings are for break-in or as a starting point for tuning. They were never meant to be the normal running settings. |
RE: Engine Help
I just got in from the garage. Took the engine apart cleaned it all up put it back together put in another brand new glow plug and tried it again, same out come. I have in Nitro for 3 years so I have a pretty good idea of what I am doing this one just has me going crazy. Any other ideas besides glow plug and being to rich?
RE: Engine Help
hmmmm,how co;d is it,outside?
RE: Engine Help
probably about 50 in the garage.
RE: Engine Help
What plug are you using, and what % of nitro?
RE: Engine Help
30% 14% oil and the plug is a Traxxas 3232x-long medium temp.
RE: Engine Help
ORIGINAL: george3.3 30% 14% oil and the plug is a Traxxas 3232x-long medium temp. |
RE: Engine Help
I wouldn't want to use a hotter plug since it needs the igniter to stay running?
RE: Engine Help
No, the hotter the plug the less nitro content necessary. If you use a med-hot plug on 30% it may overheat your engine and burn itself out really fast.
http://www.maxxtraxxusa.com/Glow_Plu..._in_herre_.cfm I can't find a better reference right now, but it gives you the idea there. |
RE: Engine Help
I will look to see if I have a cooler plug if not I will buy one tomorrow. Should I just get a cold plug O.S.?
RE: Engine Help
ORIGINAL: george3.3 I just got in from the garage. Took the engine apart cleaned it all up put it back together put in another brand new glow plug and tried it again, same out come. I have in Nitro for 3 years so I have a pretty good idea of what I am doing this one just has me going crazy. Any other ideas besides glow plug and being to rich? 3 years huh??? I got my first nitro engine in 1965. I stiil put my money on tuning. You're way too rich - probably on both the LSN & HSN. The excess fuel is cooling the GP so much that it cannot sustain ignition once the ignitor is removed. A very common problem at factory settings. Your symptoms are 99% of the time caused by one of two things - a bad/weak GP or being too rich. Since you've tried 3 different GPs I'm betting on too rich. The temp range of the GP will affect an engines performance but should not keep an engine from running on it's own. |
RE: Engine Help
My point was no to tell anyone that I know more then them I am willing to always take advice that is why I am here asking. I just wanted to let people know that I am not trying to tune my truck for the first time. If I thought I know everything because I have been doing it for 3 years I would not be asking, just rying to give as much info as possible.
RE: Engine Help
This one is simple, take the wifes hair dryer and heat the engine block up before starting the engine. Nitro engines are like desiels, they need a warm block to make combustion. LOL
RE: Engine Help
ORIGINAL: ArloRogers This one is simple, take the wifes hair dryer and heat the engine block up before starting the engine. Nitro engines are like desiels, they need a warm block to make combustion. LOL First he can get it started just not keep it running Heating with a heat gun/hair dryer only eases compression, it does nothing for the glow plug or combustion Diesel engines don't preheat the block, they warm their glow plugs A warm block has nothing to do with making combustion If your block is warm(hot) enough to make combustion then you've really got big problems To the OP, no offnce taken here, just trying to show that I have enough experience to make suggestions for you. Also, it seems that all you have talked/asked about is the GP and I really do not think the plug is the problem. Have you tried geting it started and leaning the engine out? It may take a substantial amount of leaning but start with the HSN and lean it 1/4 turn then lean the LSN 1/8 turn. Continue like that until the engine stays running. Once you get it to stay running you can go ahead and tune it for performance. Good Luck |
RE: Engine Help
I bought 2 MC9 Dynamite plugs. I am having better luck but it still won't idle more then 20 seconds. I have it sitting on my RDLogics stand and it is revving enough to get the temps up to 210-215 but need to leave the igniter on to do so. The LSN is at about 1.5 turns out and if I go up or down from there it runs worse.
RE: Engine Help
Maybe its a good time to just strip the whole truck down clean it all up and start fresh, I just don't get it. It makes all the sense in the world that is running rich but I can't get it to run leaner. Did I buy old fuel from Hobbytown??
RE: Engine Help
There are so many things wrong with those statements...... First he can get it started just not keep it running Heating with a heat gun/hair dryer only eases compression, it does nothing for the glow plug or combustion Diesel engines don't preheat the block, they warm their glow plugs A warm block has nothing to do with making combustion If your block is warm(hot) enough to make combustion then you've really got big problems To the OP, no offnce taken here, just trying to show that I have enough experience to make suggestions for you. Also, it seems that all you have talked/asked about is the GP and I really do not think the plug is the problem. Have you tried geting it started and leaning the engine out? It may take a substantial amount of leaning but start with the HSN and lean it 1/4 turn then lean the LSN 1/8 turn. Continue like that until the engine stays running. Once you get it to stay running you can go ahead and tune it for performance. Good Luck [/quote] So as soon as I get it going take the igniter off and adjust the HSN (lean it)? do you think the LSN is ok at 1.5 turns until I get the HSN set? Thank you for your help. |
RE: Engine Help
I live in WV and it'a colder than a well diggers behind here. I just went out and ran one of my trucks. It would not stay running without power to yhe glow plug until I used the hair dryer on it. It may not make since but it works. However if you had it running on the stand and warmed it up I'd try advancing the idle first and then greasing the backplate and cab O ring in case one or both are sucking air. I'm with you I've been running nitro for a little over 20 years and am still learning. Beat me up, call me stupid I don't care as long as I learn something from it. LOL
RE: Engine Help
Not sure what planet your form but the plug hanging from the desiels around here are to power BLOCK HEATERS. Without them we could not start our desiels in the winter. A simple Goggle search will get you up to speed on the subject.
RE: Engine Help
ORIGINAL: ArloRogers Not sure what planet your form but the plug hanging from the desiels around here are to power BLOCK HEATERS. Without them we could not start our desiels in the winter. A simple Goggle search will get you up to speed on the subject. |
RE: Engine Help
C..can't we all jus get along? [&:]
:D |
RE: Engine Help
What fun would that be?:D;)
