ECU V 5.0 Uaccel Menu?
MD
How do I get to the uaccel settings in ECU v 5.0 for my P200?
I tried holding the Limit key down and then pressed the + Key after applying power and it just shows the minimum RPM. Does the turbine have to be running?
I found out one thing. Don't turn it on with the Limit key depressed. It start to count up and displays flash mode. Yikes. lol
Any help would be appreciated.
Thank you
Bob
Thank you
Bob
