Xicoy ECU
My Feedback: (7)
Xicoy ECU
I posted this on the jet forum but it probably belongs here:
I’m new to Xicoy and this is what happened. On install I accidentally hooked up a 3s lipo (would’ve sworn it was one of my nearly identical 2s!). Worked fine but later on I realized my error and installed a 2s.
Even tho it worked fine for a while now I get the screen you see in the picture and can’t get out of that screen. Heeeeellppp!
Hi Buddy,
Need little help. I have purchased Xicoy latest gas start ecu and system. I am not able to power it up. I have not connected any Rx to it. Is it due to this its not powering up. I touch and hold on the digital screen but still nothing.
Do I need to connect the Rx to have it on? I don't know how to connect the throttle channel to Rx. There are three wires coming out of the ECU for Rx, Do I need to give power to Rx separately or it will come from the ECU. which cable is the signal cable?
Is system not powering up is linked with no Rx connected?
https://www.xicoy.com/catalog/produc...leo2l4v4ea6qn0
Hi Buddy,
