Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic
Reload this Page >
KT45TP-H startup flames
Turbine Clinic Get direct support from the major turbine manufacturer support reps in here.
Old 02-03-2022, 03:56 AM
Thoemse
Default KT45TP-H startup flames
Hello everyone,
I got a Kingtech KT-800 heli since september. I got quite a few flights on it by now and it is a fatastic machine.
There are however some flames during the start procedure. Not much or for long but it wasn't there during the first couple starts.
I contacted kingtech and I got new values to try (less pump voltage and less pump start value) but all it does is lenghen the startup procedure with the same behavior otherwise.
I am not talking about a burning turbine here just a couple very short visible flames. I never had a bad start or anything and it runs flawless.
Should I look into tweaking this some more or is it simply to be expected? I am using Jet A-1 with 5% Kingtec Oil btw.
You can see what I am talking about on this video at the 50 second mark:
Old 02-03-2022, 11:46 AM
Desertlakesflying
My Feedback: (28)
That is 100% normal.
Thoemse (02-03-2022)
Old 02-03-2022, 11:10 PM
Thoemse
Thanks. Great to hear. Then I'll just keep on flying. I love this thing.
