Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic
Reload this Page >
JetCat ECU-V12.0
Turbine Clinic Get direct support from the major turbine manufacturer support reps in here.
JetCat ECU-V12.0
Old 08-09-2022, 01:12 PM
venny2k07
Angry JetCat ECU-V12.0
I ran into a problem using this ECU...When applying power the green LED blinks once then goes off...is that normal? Trying to get an english version manual somewhere without luck. Thanks Guys! If someone can point me to right direction...
Old 08-10-2022, 12:32 AM
partshunt
Hi, Can you Google the manual and if it is not in English, your computer should be able to translate it to English. Maybe print it out or just save to a memory stick...
