Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
DC-3 scale landing gear plan
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 03-10-2012, 11:07 AM
krles
krles's Avatar
Default DC-3 scale landing gear plan
Like many of you, once I wanted to build a big DC-3. But right from the start, arose the problem of how to make the landing gear in a scale look. Factory-made retracts did not meet my expectations, and so had to go my own way. The development was long , not easy and not cheap. I capitalized on it near to 20 years of my experience of a professional designer, knowledge of mechanical engineering and working with metals.
Now, after three flight seasons, I can say, the retract despite its low weight (580g each) is
solid, functional and reliable.
It's time to share with you the experience.
I have created a CD with comprehensive information about the construction of such retractable landing gear (scale 1:7.5).
Disc contains:
• computer simulations of the movement for a better understanding of the principle, rendered photographs, including a proposal for mounting in the model
• set of engineering drawings of all parts (more than 40), assembly drawing and bill of material
• photos of the finished landing gear in high resolution
• HD detailed motion videos of built in retracts
• brief description, hints and tips
Altogether it is over 200 megabytes of informations revealing the secrets of the landing gear divided into easy-directories.
A complete information is now available to anyone.
I am convinced that the information from this CD will save you a lot of time, materials and energy needed for your own development.
It is worth for those of You, who wants to build a retract yourself.
So, look here http://vimeo.com/38418724 to watch a short trailer….and…. if You are interested in, please send me a PM.
Tom Krles
Please note: The content of the CD is for home use only (not for commercial use).
ID:	1737095   Click image for larger version
Old 03-12-2012, 12:09 AM
Props4ever
Default RE: DC-3 scale landing gear plan
Great that you posted this coz i'm about to get my short kit with all fiberglass parts of Ziroli DC 3, i'm already looking to get it's robart retracts but seeing you did custom CAD based design as a set, plus it's at 1:7.5 scale, so i'm sure it will work perfectly and will look great for this model being 1:8 scale.....
Now when you say your compiled CD is for guys who want to make there own gears based on ur drawing, how much machining is involved to make the parts.
Old 03-12-2012, 04:01 AM
krles
krles's Avatar
Shortly said, what You have to do:
-cut all the tubes to their length dimensions
-weld them together
-turn the rotary parts (such as housings and shafts) on a turning lathe
-make the flat parts (laser cutting best)
-obtain a few standardized parts ( screws, circlips, a motor, microswitches)
-assembly all together
So, a lot of work, but the result is itworth, IMO.
ID:	1737891   Click image for larger version
Old 03-26-2012, 11:37 PM
krles
krles's Avatar
A download version of the CDhas beenadded now .
How it works:
Mention this option in Your PM.
You receive an e-mail with a link to download the zipped file (two weeks available).
Unzip with http://www.7-zip.org/(free)
...and...save the shipping costs.
BR
Tom
Old 05-12-2012, 02:20 AM
krles
krles's Avatar
I added the tailwheel drawings and photos to the CD.
The landing gear documentation is hereby complete.
All, who purchased the CD, will receive this update by email in short and for free.
Cheers
Tom
Old 05-13-2012, 01:58 PM
Godhelper
Very nice work!
I'm building the Top Flite DC-3 these days and also made my own retracts with simple servo drive, but Yours are much nicer!
You can see mine here :[youtube]http://www.youtube.com/watch?v=96NfD9B53rc[/youtube]
Old 03-13-2014, 12:56 AM
krles
krles's Avatar
Eric Kwiatkowski from France used my plans and rescaled them for his huuuuge DC-3 with 8 metres wingspan. As a powertrain he uses a 14,4 Volts handdrill with 4S LiPo and 8mm threaded rod.
Here are some photos and a link to the site (in French only):
http://www.modelisme-racer.fr/catego...c-kwiatkowski/
Cheers
Tom
ID:	1977629   Click image for larger version
ID:	1977630   Click image for larger version
Old 03-30-2014, 11:34 PM
krles
krles's Avatar
great pics from gear testing in France with more than 200kgs load.
Videos here http://www.modelisme-racer.fr/catego...c-kwiatkowski/
ID:	1982945   Click image for larger version
Old 01-06-2016, 12:12 PM
falconerone
received the download information today, everything came through ok. THANKS!
Old 09-10-2017, 10:21 PM
javiercabra25
Good morning!
It is possible get the information about the DC-3 landing gear scale, I will built a 1/8 scale.
Old 09-10-2017, 11:53 PM
krles
krles's Avatar
...PM sent.
Old 09-11-2017, 06:22 PM
javiercabra25
Default Already!
Please check your paypal balance!
I transfered 17 usd!
thanks
Old 11-20-2019, 10:35 PM
krles
krles's Avatar
Default availability?
Yes, after seven years, data are still availble.
As a downloadlink. Simply send me a PM.
Cheers
Tom
Old 07-15-2020, 09:47 PM
krles
krles's Avatar
Default 3D files
From now, all the 3D files available.
Just PM me.
Tom
[email protected] (01-06-2021)
Old 01-06-2021, 09:27 AM
[email protected]
Default DC-3 Landing gear
Hi Tom is your DC-3 landing gear data still available?
I am building a Ziroli 1/8 scale.
Thanks Ron in the UK
[email protected]
Old 01-06-2021, 09:32 AM
[email protected]
Hi Tom is your DC-3 landing gear still available?
[email protected]
Old 01-06-2021, 02:34 PM
[email protected]
The DC-3 landing gear that Thomas has designed, features a sensible amount of scale detail without it being too complex to make. I obtained a data set, it's fantastic, 3D views, detailed component drawings, photo's, videos and much more. Highly recommended.
Old 01-13-2021, 09:00 AM
indiradeleon
Just PM me.
Tom
Hi, Im doing a polar drag of DC-3 and I would like to get those files for schoolar propuse. Can you send me to my email? [email protected]
Thank u a lot.
