MARUTAKA cessna Skymaster Kit questions
#51
RE: MARUTAKA cessna Skymaster Kit questions
My Marutaka kit plane has now flown several times.
A real ***** cat to fly, very stable in the air.
Straight and level on half throtle.
Will not fly of deck, needs to be "unstuck" with up elevator.
Vic
Vic
#52
Thanks a lot for the answer!
I looked at the photos, very informative. Is it correct that the exhaustions pass through the propeller?
I am not sure if I can get TopFlite products over here. I will look around. There will be a solution.
Last month, there was a short mention of a self-built Skymaster in a German magazine. They reported some trouble with the vibrations due to the two engines attached to the fuselage. What are your experiences? Especially since Eurolight recommends putting a 2-stroke in the front and a 4-stroke engine in the rear. According to them, this gives a nice sound. But the fuselage may need reinforcement in this setting.
Please let me know once you are air-borne or if you have any further tips.
Norbert
Norbert
#54
Tried to send lenghty reply giving more information on building of model but was timed out by website, so here is short reply
OS.40 x 2.
Used same motors, props and throttle servos anything else would cause vibration.
Got third prize in sponsored fun fly-in over the weekend.
Vic
OS.40 x 2.
Vic
#55
Compliments for the price!
Did you actually test different motors and props? That is interesting, as my distributor not only advocates 2 different motors but also 2 different props. He says that the rear prop should have a steeper slope as the air passes by faster??!! I don't know if this is fantasy or physical fact. I would very much appreciate your comments. Actually, I am waiting with the assembly and the purchase of motors and equipment until I see a clear answer for these questions. Would be too bad to loose the model due to a bad tip by the dealer, who is a distributor and not a known modeller. I would rather rely on people like you who have experience.
If the lengthy answer is still available, here is my mail address: [email protected]
Otherwise, we should stay on this forum in order to make the hints available to all others.
Greetings and thank you,
Norbert
Norbert
#56
My Feedback: (20)
Everything I have read on the real Skymaster says it has the same size props front and rear. But since they are constant speed, full feathering props, I would guess that they are not at the same pitch all the time.
Only way to be sure is to test different props on your plane but to start I would just go with the same pitch and see how things go. The unique sound of a Skymaster comes from the harmonics of the engines and the front prop thrust impinging on the rear prop. Why mess with a classic?
Don
Don
#57
Will try sending long message again.
Marutaka Skymaster kit is definitely an advanced builders kit.
There are things like wing washout that is obvious when you line up all the wing ribs but no mention of it plans or instructions.
Stab alignment parts differ from plans.
Undercarriage was of no use, if used model could never have tracked straight.
As for props _ Wash from front prop as it passes over fus speeds up, as it nears rear prop over tapered rear sections of fus it slows down and there for is more dense.
In full size model the constant speed props would allow for minor airspeed changes, but with model and fixed pitch props well? Well life ain't perfect either.
VIc
Wil try longer message direct to you.
VIc
#59
Can you tell us which company manufactures or distributes the kit? Wing span etc.? I don't have access to that magazine.
Greetings,
Norbert
Greetings,
Norbert
#61
Had the model out again yesterday. Had engine failure (front) just after takeoff, easily able to fly circuit and land on the pusher.
I have two OS .40's. 10 x 6 APC props.
Vic
Vic
#62
My Feedback: (20)
Norbert,
I subscribe to the UK Traplett Model World magazine and in that magazine there have been ads with a Skymaster pictured. These are the same models that KMP imports but it is a European importer.
I'll try to find the ad tonight when I go home and I'll get you an address/phone/website
Don
Don
ORIGINAL: N. Albers
Greetings,
Norbert
Greetings,
Norbert
#63
My Feedback: (20)
Figures: I can't find the ad now.
Here are some links to sellers of different Skymaster ARFs, though
http://www.cheetahrc.com/twin.html (KMP ARF)
http://www.jgrc.biz/en-us/dept_59.html (Aviomodelli kit...made in Italy)
Don
And watch some Skymaster videos here: http://www.cheetahrc.com/vids.html
Don
#64
NY
RE: O-2 Photos
Hello Ron
I am building Hostetler's Quarter scale and I would like to finish it in the navy color scheme, I am having trouble finding enough images to complete that task. I was wondering if you could help me out or steer me in the right direction. Or if anyone out there can help me it would be appreciated.
E-mail: [email protected]
#65
Hello, I'm building the Marutaka Skymaster from plans. However, I need a little help: Where can I find the windshield? Its not easy to mold mostly because of size. second, I would like to get the main landing gear. Also, not easy to make. Thanks!!!
#66
Hi Eduardo
Check out here, royal and marutaka are the same.
http://cgi.ebay.com/Royal-Cessna-337...#ht_1098wt_786
#67
Hi. Thank you very much for your information. Yes, Royal and Marutaka are the same. Just that Royal put there own plans and instructions for the American market.
#69
I stopped my Skymaster for lack of time. I plan to finish it early next year. I would like to install electrics but I have found so complicated and difficult the calculation for getting the correct motors, ESCs, batteries, propellers that I am seriously thinking of returning to old reliable glow engines. Just a couple of Chinese ASP .52 and that's it!!! However, I'm opened minded. Who can make for me all calculations necessary for electric installation in my Skymaster? One other bad thing about electrics: they don't make any noise at all. It is funny to see a Skymaster or any other propeller driven airplane, flying around with just a funny electric motor sound. Thanks!!
#70
I partly agree with you but the good thing of modern electric power is that it is lighter than glow one. This plane is already quiet heavy ( not as much as the Aviomodelli / Mantua one but still). Plus the advantage of balancing the plane just with the battery. The plane is already tail heavy.
#71
I also partly agree ith you. Mine is coming up not too heavy because I carefully selected my balsa, and covering will be "ChinaKote" (Chinese equivalent of MonoKote, I put that name!!) But I still like everything surrounding glow engines: fuel, glow plugs, fuel tanks, carburators and that beautiful "music" that all glow engines give!!!. I even like the castor oil residue to be cleaned after flying sessions!!! I'm joking of course, one of the nice things about electrics is cleanliness. Anyway, I will decide what I will do on January and will post it here.
#73
Short flying times, having to carry lots of batteries for a day's flying and the fact that these batteries explode!! (I've seen it!!) and are very very expensive. These are just some of the reasons why I prefer to stick with glows. Also, Glow fuel is very cheap (at least here) and easily bought and kept. Also, when the model is flying, glow fuel is burned always lightening the plane. Batteries are always heavy being charged or empty!!!!
