Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
KMP B-25 CONSTRUCTION.
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 05-28-2006, 11:34 PM
  #501
nemesis4u
My Feedback: (77)
nemesis4u's Avatar
Default RE: KMP B-25 CONSTRUCTION.
www.kmp.ca
Old 05-28-2006, 11:37 PM
  #502
kahloq
kahloq's Avatar
ORIGINAL: nemesis4u
www.kmp.ca
Unless they are simply doing maintainence all day, I have tried connecting to that website all day long without success. Thats why I asked for sites that have the kit. Got any other places?
Old 05-28-2006, 11:41 PM
  #503
nemesis4u
My Feedback: (77)
nemesis4u's Avatar
YEP GO HERE:
http://www.speedersonline.com/xcart/...cat=360&page=1
ENJOY IT!
Tomas
Old 05-29-2006, 09:07 AM
  #504
tail strike
tail strike's Avatar
I tried the link and worked just fine. try it now.[8D]
ORIGINAL: kahloq
ORIGINAL: nemesis4u
www.kmp.ca
Old 05-29-2006, 11:42 AM
  #505
TLH101
My Feedback: (90)
TLH101's Avatar
I put 5 flights on my B-25 this weekend and I have to say, it is good flyer. Really has a lot of rudder, & aileron authority. Hope that will be true if I loose an engine . I think I will need to dial in a little expo on the rudder and ailerons, to smooth out the flights. Have OS .91 4-strokes, and thats all the motor it will ever need and then some! Flying with 14x6 M/A 2-blades now but I plan to go to 13x8, or 14x7 3-blades.
I think its a keeper.
Old 05-29-2006, 12:37 PM
  #506
nemesis4u
My Feedback: (77)
nemesis4u's Avatar
CONGRATS TERRY!!
WIll you be Taking it to BOMBER FIELD this coming weekend???
June 4th??
Tomas
here is the detail of the Event that Bomber FIELD is hosting:
6/3/06 - 6/4/06 – Monaville, TX (C) War Bird Any size War Bird from any country. $20.00 landing fee. RVs welcome, no hook ups. Early flyers welcome. We have hamburgers, cold drinks, and souvenirs available. Plaques will be given. Paved or grass runways. Canopies no wider that 10 ft. in pit area. SHOWTIMES: Sat. 9am-5pm and Sun. 9am-2pm. SPECTATOR ADMISSION: 5.00 adults and 12 and under free. CD-Nick Stratos 10003 Rocky Hollow LaPorte, Tx. 77571 281-471-6762, E-mail [email protected] Sponsor: BOMBER FIELD
Tomas [>:]
Old 05-29-2006, 03:42 PM
  #507
TLH101
My Feedback: (90)
TLH101's Avatar
Yup!
Old 05-31-2006, 02:54 AM
  #508
Jimmy Bananas
My Feedback: (13)
Here are a couple of pics of the finished KMP B-25..Weight around 20 Ibs,2-Mag 91 4-strokes, Robart retracts, and bomb drop... CG is 4 5/8" from LE of wing,on the fuse..also Tru-Turn prop hubs..No weight added to achivie balance..Hopefully tests flights in June some time............
ID:	469224   Click image for larger version
ID:	469225   Click image for larger version
Old 05-31-2006, 10:55 AM
  #509
ivancant
ivancant's Avatar
Jimmy,
Nice Job on the B-25. Quick question...your retract struts. Robart? Do you happen to know the model/part number? I plan on using the supplied retracts and just add the robart struts to them. Any other suggestions?
Brent
Old 05-31-2006, 12:29 PM
  #510
rcplane-RCU
My Feedback: (7)
Hay all.
The guys from Vacaville and Woodland, CA did you all proud. They were in Atwater CA at the IMAA Rally of the Giants this past week in force and they had a mass of War Birds with several of these B-25 included. Saturday and Sunday they put on a reinactment of the Doolittle Raid on Japan, it was awesome. They had among their planes several B-25s, P-38s, P-61s and more, I don't know their total but I would guess the lot of them brought around 20 airplanes or should I say War Birds??
Thew flew with class and are very good pilots. I am recovering from the event but will post some pictures as soon as I can.
Mike
Old 06-01-2006, 01:53 AM
  #511
Jimmy Bananas
My Feedback: (13)
ivancant:
I order the kit and the retracts from KMP, at the same time..The retracts are from Robarts....units were complete..didn't have to add any struts..some people in these thread did order the Robart struts for the gear that came with the kit......I got a special deal when I ordered the B-25,and retracts..got the combo at a special price..That was last Oct....had to wait 3 1/2 months for the retracts..Just check out the thread here and maybe you'll find the the struts( Robarts) some people have added....Suggestions?...I'd get the set of Robart gear for the plane.....Pricey,but well worth it...Thanx for the comments on the plane.....Good Luck
Old 06-13-2006, 06:53 AM
  #512
scottonium
I have noticed many of you decided to mount your 4 stroke engines upside down. Many people suggest theses engines are not attitude sensitive. Can some of you elaborate on how well this has worked and what problems one may encounter. Roomer has it they are harder to start.
Old 06-13-2006, 09:17 AM
  #513
DragonLines
My Feedback: (13)
DragonLines's Avatar
I run four strokes in everything and have no problem with them inverted. You follow the same rules as other engines. Keep the tank and carb close and break the engine in well according to the mfg. Usually four stroke engines once set up require very little ajustment. I have a few that I haven't had to touch the neddle valve in years, they just run perfect every time I crank them. Saito and OS are the best but Magnum can hold it's own and is cheaper. I plan on mounting two Saito .72 four strokes inverted on this plane myself. If you are worried you can invest a little in an onboard glow driver. The one I would recomend is a Nelson hobby unit that checks the plug constantly and applies power as needed. Very neat. These units aren't cheap though. There are other choices, MAXX, MPI, Sonic-Tronics (McDainel) etc. The engines are no harder to start invert than upright, just be sure not to flood the engine and hydralic lock the cylinder. Of course this is true of any engine not just four strokes.
Old 06-15-2006, 05:48 PM
  #514
starberfarbin
starberfarbin's Avatar
Hey CB1000C....... Great looking bombbay, can you give us a little more info on what you used and how you constructed this beauty! This is certainly the most elaborate I've seen so far.
Any help would be appreciated...
GREAT thread guys!! thank you.
Stu
Old 06-15-2006, 06:36 PM
  #515
starberfarbin
MTROUNDS,
Howdee.....
How did your elect version work out with the AXI4120-18's and Jeti70 optos with the 2each side TP420032 lipos?
Did you have plenty of power and how bout the sound of those bad boys? Also flight times and setup etc.
Sounds like a neat way to go (no worries on eng out stuff!
I have searched this thread for the info but couldn't find it.... sorry if you've already posted..
Thanks in advance
Stu
Old 06-18-2006, 01:34 PM
  #516
Wildchildren
Wildchildren's Avatar
Hello ,
would like to know the weight of your B-25's . My B-25 weight is 17.85 lb.
the maidenflight will come soon.
Old 06-18-2006, 02:08 PM
  #517
TLH101
My Feedback: (90)
TLH101's Avatar
Mine is 21lbs, flys great.
Old 06-19-2006, 06:15 AM
  #518
Jimmy Bananas
My Feedback: (13)
.Mine weights in around the same ...20-21 Ibs...going to put it together and check it out,and do some engine testing this week...hopefully get it in the air later this week...right now am waiting for my new glasses...over a week ago,I was flying and on final,I saw two of them coming in for a landing.... I do believe that it was time to get the ole eyes checked...I did get the plane down in one peice..Will have a video of the test flights so stay tuned for the flight of the "Ruptured Duck"..............................
Old 06-20-2006, 01:22 AM
  #519
Wildchildren
Here is a Pic of my B-25
Old 06-20-2006, 01:31 AM
  #520
Wildchildren
a pic of my selfmade Cockpit :[
Old 06-20-2006, 01:37 AM
  #521
Wildchildren
one more:
Old 06-20-2006, 01:49 AM
  #522
Wildchildren
I have one more question:
Where you have the CG at the B-25.
Can I take the CG of the construction manual?
Or do have a others?
Old 06-20-2006, 04:04 AM
  #523
Jimmy Bananas
My Feedback: (13)
Wildchildren:
Read post # 508 for CG and other info.......................
Old 06-30-2006, 09:27 AM
  #524
Fairlane
me again,
i succeeded in doing some paint jobs in my cockpit.
also some assembly work is done.
currently i am working on the pilots.
enjoy the pics
have fun
Olli
ID:	484999   Click image for larger version
ID:	485000   Click image for larger version
ID:	485001   Click image for larger version
Old 06-30-2006, 12:18 PM
  #525
tail strike
no picks [&o]
ORIGINAL: Wildchildren
