Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
KMP OV-10 Bronco
Old 05-09-2014, 11:49 AM
  #176
dmyers0403
My Feedback: (48)
Originally Posted by pattnut
KMP's recomended CG is SPOT ON!! I now have many flights on mine, and I haven't changed the CG one bit, and I have Sierra retracts in mine (balanced it gear up).
Old Dawg
Same on mine, been flying many years since it came out.
Old 05-09-2014, 02:01 PM
  #177
gromitvt10
My Feedback: (19)
gromitvt10's Avatar
I've got Shindlin retracts in mine too and the CG is correct.
Old 05-13-2014, 07:51 AM
  #178
lozza1965
Not much more to do, can i ask how many did C of G with wheels up, also a few pics of the build
ID:	1994967   Click image for larger version
ID:	1994968   Click image for larger version
ID:	1994969   Click image for larger version
ID:	1994970   Click image for larger version
ID:	1994971   Click image for larger version
ID:	1994972   Click image for larger version
ID:	1994973   Click image for larger version
ID:	1994975   Click image for larger version
ID:	1994976   Click image for larger version
ID:	1994977   Click image for larger version
ID:	1994978   Click image for larger version
ID:	1994979   Click image for larger version
ID:	1994980   Click image for larger version
ID:	1994981   Click image for larger version
Old 05-13-2014, 10:06 AM
  #179
Johng
That's an outstanding finish. What kind of paint. And who did your paint masks?
Old 05-13-2014, 12:04 PM
  #180
dmyers0403
My Feedback: (48)
I balanced mine with wheels "UP" and it fly's like a trainer. Wheels down just adds a bit of added nose weight to make the landing easy as can be. I have the Zenoa 20E on mine, so I am very curious how your DLE20RE performs as I love the rear exhaust and carb to keep from the cutting the cowl up. I have bought new cowls and PTE36 rear carb & exhaust for a future update.
The 20's fly great,just wont do any loops from level flight but the DLE's may have the extra power needed. I love how the OV-10 looks on steep full flap approaches. You can sit her down on a dime.
Old 05-13-2014, 02:38 PM
  #181
lozza1965
hi guys cheers for the info reference C of G , will balance wheels up, as for the paint masks i did them all myself, got a small vinyl plotter, idea for making paint masks and stickers, though Bronco is all paint masks, as for the paint its Klass Kote.
lozza
Old 09-05-2014, 11:23 AM
  #182
lozza1965
Had maiden flight today, well chuffed not a single trim change to be made.
1
OV-10 Bronco by lauriehughes, on Flickr
2
3
4
5
6
7
8
Laurie
Old 09-05-2014, 01:23 PM
  #183
gromitvt10
My Feedback: (19)
gromitvt10's Avatar
Nice!!! I haven't flown mine in years, it's sitting on a crate in the basement. I gotta get it out again soon.
Old 09-06-2014, 01:52 AM
  #184
yojoelay
Hi Lauriehughes
Do you have any tips on installing the Shindin retracts? I have just ordered a set.
J
Old 09-06-2014, 09:50 AM
  #185
lozza1965
Originally Posted by yojoelay
Hi Lauriehughes
J
Yes lots of cutting, I will take some photos and put on here, also beef up the rear the woodwork is not sufficient
Old 09-06-2014, 03:07 PM
  #186
Johng
I was going to ask if I could buy a set of those masks from you, but saw where you are located.
Any chance you'd be willing to share the cut files? I have a friend that does vinyl.
I wouldn't want to use your more unique wartog-ish nose markings, but the standard MARINES and star-bars would be very useful.
Old 09-11-2014, 09:56 AM
  #187
Thunderbolt47
My Feedback: (8)
Thunderbolt47's Avatar
Congrats on the maiden. It will soon become your favorite plane in the hanger. I know mine is.
Kelly
Looks real nice BTW.
Old 12-21-2014, 09:09 PM
  #188
Johng
At long last, my old horse left the ground.
It flew well, but the right engine busted a motor mount bolt. The other 3 mounts seem to have torn through the firewall which allowed the engine to sag in the cowling during flight. Luckily, this resulted in the throttle pushrod pulling the motor back to idle. When I heard the engine go down, I was in a good part of the sky so I just pulled throttle back to idle and brought her in.
As I landed, the right main gear came apart. The spring pin that served as the axle of the "knee" joint in the retract had worked its way out during the flight, As I touched down, the trailing link kicked back out of the way and the landing was completed on the bare end of the main strut. Made a horrible sound scraping on the pavement.
So, I'm lucky to have it back in one piece. I believe now that my problems stem from an unblanced prop on the right side. It started last week when I was tuning the engine and the prop bolts backed out. I didn't think anything of it. Actually, I thought I just hadn't tightened the bolts well.
Today when I was doing the final mixture tuning, I noticed that there was some excess shaking on that motor. But I pressed ahead, which shouldn't have happened. The broken mount and the missing spring pin both point to excess vibration as the cause. I should have stopped and chased down what was probably an out of balance prop. As I said, I'm lucky it is still in one piece.
Old 10-25-2015, 04:27 AM
  #189
snobird
My Feedback: (36)
snobird's Avatar
I see everyone loves the C G location, but where is it. .? Manual page is closed. ,
Old 10-25-2015, 01:41 PM
  #190
nemesis4u
My Feedback: (77)
nemesis4u's Avatar
HOW MANY OF YOU would like ... I MEAN , LOVE to have this model return ???
And if it returned what improvements would you like to have ???
This is just a query... nothing is planned as of now.... but I love the BRONCO ...
If there is enough interest , I may be inclined to bring it back to market...
SNOBIRD... I will see if I can get a copy of the instruction manual for you...
Please email me at: [email protected]
-TOMAS
VQ WARBIRDS
"KEEP 'EM FLYING"
www.vqwarbirds.com
[email protected]
Old 10-25-2015, 02:08 PM
  #191
Low Show
My Feedback: (10)
1000% YES Same size, round the corners of the Tail Booms, fully sheeted flying and control surfaces, no lighting holes in the booms and mounts for Scale Retracts, oh an A or D Nose Option. Or everything I did to the one JohnG now has...Don
Old 10-25-2015, 04:26 PM
  #192
dmyers0403
My Feedback: (48)
Agree and Improve cowl fit, detail at top of wing. Use better thicker canopy material. Still flying mine and favorite.
Old 10-25-2015, 04:37 PM
  #193
Mpizpilot
My Feedback: (45)
-TOMAS
VQ WARBIRDS
"KEEP 'EM FLYING"
www.vqwarbirds.com
[email protected]
Yes,yes,yes! I'll preorder one now. I've always been annoyed I missed the boat on this one. And yes also on the canopy material. That goes for all ESM planes.
Old 10-26-2015, 05:52 PM
  #194
dmyers0403
My Feedback: (48)
Still have mine but ready for another one
Old 10-27-2015, 03:39 AM
  #195
snobird
My Feedback: (36)
snobird's Avatar
Please, I need the C G , thanks, have no manual
Old 10-27-2015, 12:45 PM
  #196
Thunderbolt47
My Feedback: (8)
It's been a while but I think mine is balanced on the wing tube. I remember starting slight nose down but after the first flight I balance level. Its been there ever since.
Kelly
Old 10-28-2015, 10:27 AM
  #197
dmyers0403
My Feedback: (48)
Pretty sure I also balance mine on wing tube. If memory serves me well I just used a small rope (cord) looped under spar then up over a broom handle held over plane. Small rope fit between mid wing and outer wings for balance. Was tail heavy and put about 2-1/2 lbs up in the nose.
That reminds me that the retract mounting area should be strengthened if offered again. Bulk heads are way to light and fragile. Also re-designed to fit after market gear like Sierra or Shindin or a good set from factory!!
Old 11-01-2015, 11:23 AM
  #198
Ron101
My Feedback: (22)
Ron101's Avatar
YES!!!! bring it back..... I'm in!!!!!! I have plans and have been wanting to build it for years but time is short
has to have the short nose, keep it light, I will do twin electric
can I get on an email list to know when and if this comes out?
I would love to recommend a scheme as I have always loved this one
Name:	DSC_4277 OV-10B N338RC BuNo 158301 right front m.jpg
Old 11-03-2015, 06:50 PM
  #199
nemesis4u
My Feedback: (77)
nemesis4u's Avatar
Gents,
So... ESM said this design was so old they don't have any of the original molds any more or plans/instructions...
they have moved 2 times since then...
On the table right now we are contemplating new twins... MOSQUITO, P-38....JU-88...new OV-10... all in the 90" range..
decisions , decisions,,, which to do first....
Hang in there...
VQ WARBIRDS
"KEEP 'EM FLYING"
[email protected]
www.vqwarbirds.com
Old 11-04-2015, 05:22 AM
  #200
dmyers0403
My Feedback: (48)
Still prefer the OV10, its a great easy flyer, easy profile to see and a safe twin in most cases. Would prefer to stay at 96 inch wing or a bit larger. But what the hey, I'm a plane junkie and lov-em all.
For anyone interested there is a great design build in progress on rcscalebuilder by Gains Smith.( http://www.rcscalebuilder.com/forum/...TID=24163&PN=1)
He has built two based on the Palmer plans and is in process of designing a better scale version. He may end up offing it as a kit, possibly with fiberglass booms and pod, but it will be some time before he is done. It is in the very early stages. He is a master designer and builder and a kit (if offered) would be second to none.
