Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
 Top Flite Cessna 310 posted >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 12-16-2013, 02:29 PM
  #3726
Callie graphics is the place I use a lot...shes awesome!!!
Old 01-01-2014, 07:23 PM
  #3727
My Feedback: (92)
Pulled mine out after it has sat for a couple of years. I love flying this model! Here are a few pics taken by my friend Derek Abramson of these flights. Radio is JR12X, power is a pair of Evolution .52's. BVM brakes on the mains. I have 90 flights on the model.
ID:	1953292   Click image for larger version
ID:	1953293   Click image for larger version
Old 01-02-2014, 09:13 AM
  #3728
Great pics TonyF
I'm just picking at mine mostly finishing up my BME pitts and then i'm jumpin right on the 310
Old 03-12-2014, 06:26 AM
  #3729
Been working on my 310....just curious anyone here have the OS 46AXs on there? Any one switch the carbs to the 46AXII carbs? I cannot get those needle valves to fit in the nacelles. I figure the 46AXII carb/needle valves like the 55AX would fit a lot better. I already orderd 2 should be here by the end of the week.
Old 03-12-2014, 06:30 AM
  #3730
P-Y
P-Y's Avatar
Actually, .55 AX carb/needle valves don't fit in.
I had to cut holes for them.
Old 03-12-2014, 06:38 AM
  #3731
bmosinski's Avatar
You could just order the remote needle valves. That will allow for better placement.
Old 03-12-2014, 11:21 AM
  #3732
PY I know you have to cut holes for the valves but to try and get a regular .46 needle to fit where your cut holes is damn near impossible. thats why up upgrading valves
Old 03-14-2014, 12:16 PM
  #3733
was just wondering: what are remote valve controls. also, if you upgrade your valves on the OS46max ax's, what new valves would you use? thanks.
Old 03-14-2014, 12:34 PM
  #3734
bmosinski's Avatar
Default Remote needle valves
Here are some links to remote needle valves. Scale builders use them to relocate the needle valve so it is not obvious. Hope this helps.
http://www.palomarrcflyers.org/RCStu...edle_valve.htm
http://www.advantagehobby.com/62496/...FY3m7AodemAA7g
http://www.advantagehobby.com/46649/...FUcV7Aod81QATQ
http://www3.towerhobbies.com/cgi-bin...P?I=LXG924&P=8
Old 03-15-2014, 12:09 PM
  #3735
WOW! Thanks for the great reply...bobg
Old 03-16-2014, 12:58 PM
  #3736
I'm using the OS46II carb. Itss the same carb as the 55AX
Old 03-17-2014, 03:24 PM
  #3737
Ive got the OS 46 max ax's motors on my plane, with, I assume, the original carburetors. Is there a better, newer carb for this engine? I'd like to know if there is a way to get more power with the same motor. I'm not a fan of the 55ax. If anyone has any ideas, please let me know. thanks for the help. best, orion...
Old 03-18-2014, 07:06 AM
  #3738
Orion,
The OS 46AX was replaced by the 46AXII the only difference i s the carb. Which I have the 46AX and replaced the AX carb with the AXII carb.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCABL
Buy the way is there any easy way to do the nose gear doors with 2 air cylinders? Im having one hell of a time lining doors up too work since they have a curvature to them.
Old 03-18-2014, 12:11 PM
  #3739
dear bad, go to YOUTUBE.COM and put in TINKERMANRC. This guy has built some really nice planes, including the Cessna 310, and he made doors for the nosegear from, I think the set you can buy. look at his video, one of the three building segments for the 310, and then email him. he can provide direction for fitting the doors and installing the air cylinders. good luck. best, orion...
Old 03-24-2014, 11:34 PM
  #3740
dkm
dkm's Avatar
Has anyone tried a gas version for the 310, either the Evolution 10cc or the NGH GT9 9cc gas engines ?
Old 03-25-2014, 05:35 AM
  #3741
Thanks for the info Orion.
Tinkermanrc did the twin DLE20s in this: https://www.youtube.com/watch?v=06UOj3y714I
Old 04-24-2014, 06:13 PM
  #3742
Im following your advice and get baffled. is the thin balsa saw blade a special blade, or is it in a exacto kit? next, im not sure what you mean when you say make a square ledge that you can bite into with some screws and will keep it level. are you talking about using the square that was removed as a replacement patch with some screws in it? love to know....best,,, orion4455.
Old 04-25-2014, 06:01 AM
  #3743
My Feedback: (7)
Default new build
Well, after flying the heck out of my old 310, I decided to build a new one.
I made a few changes on thus one.
1) removed the balance shot from the nose. I'll use batteries, engine weight to help balance.
2) added better lighting (bright LEDs)
3) use dle 20s
4) added aluminum torque tube to the forward part if the wing. This tube Ru s fro. The center of the wing to the nacelle. It also runs the wires through it. Thus should stiffen the with g and provide resistance to twisting the wing due to heavy engine es.
5) I repainted the dark blue trim color.
Jim
Old 04-25-2014, 06:12 AM
  #3744
Nice paint job Jim. For what it is worth, I drilled a 3/4" hole in the front of the nose wheel well which allowed me to chip aware all the lead. The retracts covers up the hole for a clean look,
Ron
Old 04-25-2014, 08:18 AM
  #3745
My Feedback: (7)
Interesting, I should have tried that. I carefully cust a small hatch with a metal bladed saw with my dremel and then pop'd out the shot. The hatch can be glued in rather easily with minimal paint touch up. However, your idea would have been cleaner.
Jim
Old 04-25-2014, 10:30 PM
  #3746
My Feedback: (9)
Wow Jim, that green trim really pop's and looks great. I am going to repaint the lighter blue on mine with a bright red color, but still have not decided on the correct shade to use. I am using the Klass Kote epoxy system, what paint did you use on yours? Thanks
Old 04-26-2014, 08:04 AM
  #3747
My Feedback: (81)
I don't remember what I posted. Can u resend?
Old 04-26-2014, 07:30 PM
  #3748
Hello RK-Aircraft! I wasn't clear about how to remove the steel shot in the nose of the cessna310. fortunately, ive received several notes that tell me how to do it. But, thanks for checking with me...best, orion4455
Old 04-26-2014, 08:46 PM
  #3749
My Feedback: (7)
I wanted to paint the light blue, but it was a lot more painting...I guess I am lazy. I used model master enamel paints and then cleared with ppg urethane enamel. I have used this many times with great results.
Old 05-09-2014, 09:14 PM
  #3750
My Feedback: (7)
Getting closer to maiden flight.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
