Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
 Top Flite Cessna 310 posted >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 02-06-2007, 11:22 AM
  #901
Default RE: Top Flite Cessna 310 posted
GI Joe action figure accessories..But I don't see them in the stores ant more..
Old 02-06-2007, 12:14 PM
  #902
ORIGINAL: orvel
Nice! I may fly the maiden with 2-bladers but eventually I'll go to 3 blades. Is that a Tru-turn spinner?" If it is which one is it? Also what size prop is that? Thanks!
Do you plan to use TwinSync? I just finished installing one on another airplane and continue to be impressed at the thought that went into the design. Engines do quit and sometimes frequently. Even a minor Cessna crash would be detrimental to the appearance.
Bill
Old 02-06-2007, 01:08 PM
  #903
I have a question for you master builders out there, does someone make a solid state switch for turning on those LED's using a spare channel?
ACP
Old 02-06-2007, 01:11 PM
  #904
I use a Electro-Dynamics onboard glow electronic switch, pluged into a spare channel..
Old 02-06-2007, 01:22 PM
  #905
My Feedback: (23)
pettit's Avatar
Here's a solid state switch kit that will work. I have an older version that only works with 4 cell batteries, but the new one says it'll work from 4.5 volts to 10 volts on the input.
The price is right, $15.00 and easy to assemble too.
http://www.hansenhobbies.com/products/rcelkits/erskit/
Old 02-06-2007, 01:31 PM
  #906
Thanks!
teamscalepilot
Old 02-06-2007, 01:34 PM
  #907
Dick
Nice! I'm going to give it a try.
Thanks!
Old 02-06-2007, 02:10 PM
  #908
My Feedback: (12)
DAN AVILLA's Avatar
I'm in the process of installing the OS 55 s . I had to sand the top fin to get clearance. They will work fine but the hole needel valve assembly and base will hang out the top of cowl. Do they make a plug for carb and a relocation kit ? Thanks Dan Avilla
Old 02-06-2007, 02:20 PM
  #909
Dan,
I have not installed my engines yet. This is good info. Can you post pictures of the assembly with the nacelles on the wing. I don't know if there is a relocation kit for the carb/needle valve assembly.
Old 02-06-2007, 03:11 PM
  #910
My Feedback: (12)
DAN AVILLA's Avatar
I'm going out of town to Phoenix to fly Jets . Will take a picture when I get back. Dan
  #911
My Feedback: (13)
RAM sells a digital switch ,P/N RAM35 Simple Switch.
Old 02-06-2007, 03:15 PM
  #912
Guys I hate to be beating a dead horse, but I have to ask/comment. From what I understand, the twinsync will sync engines throughout all operations, idle to full power, and shut the other engine off in the case of an engine failure. Is this correct? If so, I believe you are putting your perfect airplane at serious risk should you ever have an engine failure. Based on the Top-Flite releases, and visually seeing it, the built in outward thrust will allow this plane to be controlled in the case of a single engine failure. I would want to be able to go to full throttle with the one engine I've got left in the case of failure. It could be just what you need to make it back to the field. Just my .02
Old 02-06-2007, 03:26 PM
  #913
B Shipp
Cool! I have already purchased the Hassen Hobbies kit switch that Dick P suggested, however I will definitely consider this one on the next project.
Thanks!
ACP
Old 02-06-2007, 04:08 PM
  #914
My Feedback: (65)
dbrown711,
According to the info I read about the Twinsync, the "good engine" goes to idle upon engine failure. This is to help you maintain aircraft control immediately after the failure occurs. However, all you have to do is return the throttle to idle to regain control of the good engine. Hope this helps.
Old 02-06-2007, 04:15 PM
  #915
My Feedback: (65)
Hey guys,
Just wanted to let you all know that my retracts came back from Robart today. Took about ten days. Not bad considering how many they must have had to do.
Old 02-06-2007, 04:37 PM
  #916
My Feedback: (14)
handyman_alw_'s Avatar
Rick,
Got mine back yesterday. did they tap the holes they drilled yours? they did not in mine so I was just wondering if mine where done or they forgot to tap them.
Allen
Old 02-06-2007, 05:41 PM
  #917
My Feedback: (9)
ORIGINAL: teamscalepilot
Stick your head inside the and check out the lead shot that is already inside the nose. I'm sure it's there for a reason!!!!!!!
Well I gave the factory pilot the boot and used a Barbie & bad ars GI Joe. (They are behaving themselfs this time!!
What do you call a GI Joe in his Cessna 310 with 3 Barbie Hooters Girls???? LUCKY
Im going to do Penny and Sky King. In western suits to matchThe 310's color.
Western hat's are available here: http://adollysworld.com/doll_hats.html
Just $1.00EA.
Old 02-06-2007, 06:37 PM
  #918
Gosh, where is Twinman when you need him?
Old 02-06-2007, 06:41 PM
  #919
ORIGINAL: rcaston
dbrown711,
I have a Twinsynnc but maybe Bill W. the designer will clarify the operational capabilities.
Old 02-06-2007, 07:19 PM
  #920
My Feedback: (18)
Welp,, as with any multi plane, there is no substitute for flying skills...
The Twin Sync is an AID... Should an engine quit the unit will cause
the other to come down.. Then once the pilot brings the throttle
stick down the unit will allow for full control of the running engine..
This is so you KNOW you have an engine out and not to jam the
throttle causing a death spiral... Once you have control of the
running engine you can add in rudder and continue flying...
Robby
Old 02-06-2007, 07:28 PM
  #921
Wondered if the good things being discussed about Robart will also be deleted?
Old 02-06-2007, 08:03 PM
  #922
My Feedback: (65)
Hey Allen,
Mine were drilled and tapped. They got here just in time. Just about finished the wing this morning. All I have to do install the gear and run the air lines and it's done. Starting on the fuse tonight. The OS 50SXs dropped right in. So far the fit on this bird is the best I have ever seen.
Old 02-06-2007, 10:49 PM
  #923
Here are some pictures of today's progress, once you cut away the monocote you will find a nice fiberglass wheelwell liner white in color!!!!
Also installed the Elevator and Rudder servo's, you'l find very little play in the pushrods and control surfaces are NOT Soft.
Did some work on the gear doors. I plan on having the inner doors and nose gear doors workable. STAY TUNED!!
Digging thru my libary I found a 3 view of the 310..
ID:	615503   Click image for larger version
ID:	615504   Click image for larger version
ID:	615505   Click image for larger version
ID:	615506   Click image for larger version
ID:	615507   Click image for larger version
Old 02-06-2007, 11:56 PM
  #924
Is anyone else out there using OS 55's and do they actualy fit?
Old 02-07-2007, 03:28 AM
  #925
My Feedback: (29)
mrdakota's Avatar
I'd like to see pictures of those .55's installed with the needle valve cut out.
Keith
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
