Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
 Top Flite Cessna 310 posted >
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 02-26-2007, 08:14 PM
  #1176
Default RE: Top Flite Cessna 310 posted
I was looking at the exposed wood under the flaps. It looks like an area where fuel will work its way under the covering and start peeling back with time. I was thinking of sealing the edges where covering meets bare wood. Should I use epoxy to seal this area and then paint, or does anyone have any other ideas? I read where someone used nail polish and another person painted the area. I would think the fuel wood cause the area to bubble with time. Can I mix paint into the epoxy? Thanks
Old 02-26-2007, 08:17 PM
  #1177
My Feedback: (10)
bob1393's Avatar
Bobby,
Got the Saito 82's installed - inverted. Only the bottom of the Nacelle had to be cut. Also need one small hole on the side for a needle valve extension.
Bob
Old 02-26-2007, 08:42 PM
  #1178
orvel's Avatar
Puncho, I plan to mix up a batch of 30 minute epoxy and thin it out with alcohol then apply it to the flap area, this will seal the wood after it dries. Then I'll follow with a coat of flat fuel-proof paint, and believe me that'll work real good and no problems with fuel exposure after that!
Old 02-26-2007, 08:51 PM
  #1179
Thanks To Dave Turner we have inner doors. Not much room in there, he had to make some clearance for the air cylinder. And to compaire is a picture of our Barron-55 inner gear door.
ID:	630574   Click image for larger version
ID:	630575   Click image for larger version
ID:	630576   Click image for larger version
ID:	630577   Click image for larger version
Old 02-26-2007, 09:04 PM
  #1180
Excelent...... are you gonna send us some pix?
Old 02-26-2007, 09:49 PM
  #1181
orvel, Thanks!
I was reading through the directions again and It said " Whenever the term glue is written you should rely upon your experience to decided on what type of glue to use". What is everyone else going to use, CA or Epoxy?
Old 02-26-2007, 09:56 PM
  #1182
My Feedback: (65)
Puncho,
I did it exactly the way orvel did it. I used epoxy mixed with denatured alcohol, brushed it on, and waited until it dried. Then I masked it all off and sprayed it with matching LustreKote. Looks great and totally fuel proof.
Old 02-26-2007, 11:01 PM
  #1183
orvel's Avatar
Puncho, when you're building any airplane the rule-of-thumb is high stress areas (wing joiners, firewalls, landing gear supports, flying surfaces, servo block mounts/trays, etc.) you use epoxy, other general areas is a matter of preference. The manual also tells you when to use a specific type of glue.
Old 02-27-2007, 12:31 AM
  #1184
My Feedback: (10)
bob1393's Avatar
Bobby - I'll post some pics tomorrow.
Bob
Old 02-27-2007, 03:53 PM
  #1185
bmosinski's Avatar
Hey all, I have been reading this forum keep it up! All great information. I built a 310 for a customer that also used 2 - Saito .82's but I just mounted them sideways and extended the throttle arms with extenders I machined from plastic. Cutting the nacelles was a bit tedious; however I was able to keep the hole/s to a minimum. I used the stock muffler with a slot down the side. If it was mine I might have inverted or at least used a flex pipe for exhaust. But the customer gets what they want.
Also be careful “painting” the flap area the seam at the back of the flap box below the hinges had a little gap and I didn’t notice. Seal this area with a little gap filling CA then seal or paint. The result was a dark line under the MonoKote that showed through. I had to remove a small section of the covering and sand a little to remove it. It turned out OK though since the new covering looks like a panel line, although I kind of lost the “scale appearance” with 2 mufflers hanging out the side. )
Another area I had to give a little love too was the aileron servo hatch. The ply step that you screw the servo hatch to was a little loose so give that some CA before you screw in the hatch. We elected to not put the bigger gear doors on but I love to see how you guys are tackling that job. A couple guys in the club are semi-scaling out their 310’s with better cockpits, doors and more. I will see if I can get them to post.
“If its worth doing, its worth doing it right”
Old 02-27-2007, 04:00 PM
  #1186
My Feedback: (65)
Hi TSP, Looks awesome as usual. Can you tell us the items you purchased and where you got them?
Old 02-27-2007, 04:33 PM
  #1187
Dang.......
Ordered the retracts one month ago, was supposed to be here late Feb. Just checked again and now they are saying mid-March.[>:]
What ever happend to instant gratification
On an other note, Saito's due here today. I'm waitin on FED EX guy like a father waits for his daughter to come home from prom nite ! "Where is that dude"
Old 02-27-2007, 06:59 PM
  #1188
My Feedback: (17)
jiannliang's Avatar
I ordered my cessna 310 & retract from Tower hobby on 2/7 and both still in back order. They change the in-stock date all the time, the most updated schedule is mid-Mar. gee...how long I gonna wait to spend some good money.
Old 02-27-2007, 07:06 PM
  #1189
My Feedback: (65)
As long as it takes if you really want one!!!!!
Old 02-27-2007, 07:45 PM
  #1190
My Feedback: (10)
bob1393's Avatar
Bobby - here 2 pics with Saito 82's mounted inverted. The piece of plywood in the photo will be monocoted and screwed in place to reduce size of the opening. This way it can be removed in the event you want to remove the nacelle. The small hole in the front of the cowl is for the "Twin Sync" magnet pick up device.
ID:	631137   Click image for larger version
ID:	631138   Click image for larger version
ID:	631139   Click image for larger version
Old 02-27-2007, 08:22 PM
  #1191
Bob
Old 02-27-2007, 08:37 PM
  #1192
Bob
The Fed Ex Dude showed up with the Saitos.... SWEEET
I ripped open the box and flew downstairs with one motor in hand. I got to be lookin, and thinkin. Then I broke out the dremmel.
About an hr later I had the left engine mounted horizontally with the cowl on and only the chrome rocker boxes sticking through and only a VERY small portion of the top side of some fins. I am So STOKED. It lookes totally cool. I am going to slightly "blister" the cowl where the fins are. The rocker boxes do not offend the cowl one bit in my mind.
Now just have to work out the throttle linkage. On the exhaust, I'm going with a flexable exhaust pipe that will exit out one of the two exhaust ports on the "belly pan"
Old 02-27-2007, 10:19 PM
  #1193
Well Gentlemen, it flys and it is still in 1 peice after 8 flights in Jacksonville Festival Of Giants this last weekend. Lost an engine on the first flight but was able to get it back to the runway on one engine. I did clean my shorts afterwards! OS 55s performed excellant and are still breaking in on 12x6 props. A great airplane and Top Flite really out did themselves on this one! Have fun all of you cause your gonna love this plane.
ID:	631291   Click image for larger version
ID:	631292   Click image for larger version
Old 02-27-2007, 10:24 PM
  #1194
My Feedback: (135)
Meesh's Avatar
Congratulations!
Bob
Old 02-27-2007, 10:31 PM
  #1195
My Feedback: (135)
Meesh's Avatar
Hey All!
I was just surfing Tower. they have the OS .50SX ringed in stock!!!!
Limited Quantities though.
Bob
Old 02-27-2007, 10:34 PM
  #1196
I thinned and epoxy-ed the under exposed wood flap areas as recommended from this thread. I then painted that area with Rust-Oleum Appliance Epoxy sprain paint. It looks good. I think it's sealed from any fuel exposure. I also spray painted the area where the Robart retracts will mount under the wings. It looks a lot better then the bare wood look. With the retracts being held up until mid March, I'm in no rush and will take my time and build this plane right.
Old 02-27-2007, 10:50 PM
  #1197
Aerotech for the hinges and methel acralate glue . Bob violet for the door cylinders. Standard Robart wheels ( we made em fit pictures later)
Old 02-28-2007, 12:03 AM
  #1198
My Feedback: (10)
bob1393's Avatar
Hi Mike -
I think yours is the first report of a flight on one engine. I think we would all be interested in knowing if you idled back the running engine and landed as if it were a dead stick, or were you able to keep power on the running engine and keep the plane flying?
Bob
Old 02-28-2007, 10:39 AM
  #1199
My Feedback: (9)
Congradulatons Mike On your Engine Out Success. Glad I hung on to the .55AX's. Please us know how you handled it.
Thanks for the Pix.
Old 02-28-2007, 10:46 AM
  #1200
MinnFlyer's Avatar
Nice to see some flying pics!
And another "Kudos" for bringing her down in one piece.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
