Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Antonov AN-22
Old 03-30-2007, 12:03 AM
Props4ever
Default Antonov AN-22
I am giving serious consideration to Antonov AN-22 as my next giant scale project as soon as S Connie is test flown this summer. I want it to be same scale as S Connie at 1/14th Scale. Since An-22 has wingspan of 211' at 14th scale it will be 15.07' or say 15'1" for easiness. I would want to power it with 4x .90sz glow engines or G20 gassers!. Dose anyone know if there is a model of this beast that already exists as RC model?, if it does then i like to know about it and its builder. One major problem that already occurred is no info on its airfoil/s on the net, if anyone have this info please let me know so i can see what RC airfoils i can use on this model.
ID:	652778   Click image for larger version
Old 03-30-2007, 02:00 AM
Yury
Default RE: Next project Antinov AN-22
If you need help from Russian speaking man, let me know.
Props4ever
Default RE: Next project Antonov AN-22
Here are both root and tip airfoils i have found:
Antonov An-22 Antheus TsAGI S-5-16 TsAGI S-5-13
Now can anyone who have airfoil generation program can draw profiles for me on PDF files, i would highly appreciate you help.
Old 03-30-2007, 02:01 AM
Props4ever
ORIGINAL: Yury
It's not Antinov, it's Antonov.
Thanks Yuri, you almost got me on that one....
Old 03-31-2007, 11:45 AM
F86_SABRE
Prop..try here:
http://www.profili2.com/eng/default.htm
Reuben
Old 03-31-2007, 12:18 PM
Props4ever
Thanks Reuben,
I will download Profili 2 and see what it can do for my application, it does have 12% and 8% TsAGI airfoils but i can't see them for some reason without downloading the program at this time.
Old 03-31-2007, 02:15 PM
F86_SABRE
Props,
Can you get hold of the airfoil co-ordinates. That is the most important part because then you can import them into the program.
Reuben
Old 03-31-2007, 05:56 PM
Props4ever
Sabre,
I spent whole night trying to find its airfoil without success myself till this was sent to me "Root: TsAGI S-5-16 Tip: TsAGI S-5-13", i don't know where to find airfoil co-ordinates for An-22....
Old 04-01-2007, 04:24 AM
F86_SABRE
Prop,
I should think that you need not make the original airfoil. Instead you can use NACA type. What you need to find out is whether the original airfoil had a droop down leading edge which judging by the above drawings they were not. Consequently I shouldn't think that making a different airfoil would prejudice the model's flight. Maybe you should think of a percentage washout or a different type of tip airfoil so that the program can provide you with a blended wing. Naca 4415 for the root and 2415 for the tip is a good starting point (4415 is a thicker type of airfoil).
My 2 cents
Reuben
Old 04-01-2007, 05:47 AM
wingman371
deleted
Old 04-01-2007, 11:46 PM
Props4ever
ORIGINAL: F86_SABRE
Prop,
My 2 cents
Reuben
Sabre,
That is exactly what i intend to do also, pick up new airfoil for this bird, but i still intend to find its actual airfoil shapes as i have never seen them before, I was more thinking on lines of using Naca 2418 for root and 4412 for tip, same airfoils as my Connie's...
Old 04-08-2007, 02:50 AM
Props4ever
Still under works, what would be good airfoils for this beast, plus what construction method would be fast, easy and economical for this build. Since the main under carriage retracts sort of like C-130!, could its retract principal work on this model?, any recommendations would be great...
Old 04-09-2007, 02:24 PM
schwatd
schwatd's Avatar
Default RE: Antonov AN-22
Remember on the AN-22 I think half of the main gear trucks rotate with the aircraft turns so that they don't rip the tires off the beads. Also how are you going to replicate the overall droop from wing root to wing tip and the flex upwards when the aircraft is in flight?
Old 04-09-2007, 02:58 PM
canadagoose
canadagoose's Avatar
I would think it best to model the wing as it would be in level flight or close to it. I would think it would be very hard to actually model the wing flex the fullsize 'Cock' has.
Old 04-09-2007, 07:31 PM
Props4ever
ORIGINAL: canadagoose
This is how flex will be adapted in the outer wings of AN-22, it was done in DS Tu-95 so it can be done on AN-22's wing also. http://www.scaleaero.com/tu95_Wing_Flex.htm
As for inner wings they will have fixed anhedral droop from root to mid wing joint point.
An-22 Taxing:
http://www.airliners.net/open.file/0653566/L/
An-22 Flying:
http://www.airliners.net/open.file/0727635/L/
It seems as there is flex joint points in between both engines on the wing!, i doubt it can be done on the model as wing will become very fragile and unpractical!...
Schwatd:
I am or now rather say wasn't aware that last boggie/truck on the main retracts of An-22 turns to help safe tread on other tires and also to help this beast make sharp corner turns similar to B777, now this could be complicated, i am sure by the time this project gets to that stage i will come up with method to resolve this also.
Old 03-17-2008, 08:42 AM
CESARSKYDIVER
Im building one.
124 inches wingspan
all foam (white/blue), with CNC cutting
glassed fuselage/wings)
retracts (the most dificult part of tye project->i-ve made more than 8 different studies to find one relatively easy to build and to operate in grass fields)
Profiles: Root:S7055 and tip:E214
4 brushless Komodo
2 packs 2.100 Miliampers Li-Poly, 11,1 volts, series/parallel
aprox.5kilos AUW.
ID:	905687   Click image for larger version
ID:	905688   Click image for larger version
ID:	905689   Click image for larger version
ID:	905690   Click image for larger version
ID:	905691   Click image for larger version
ID:	905692   Click image for larger version
ID:	905693   Click image for larger version
ID:	905695   Click image for larger version
ID:	905696   Click image for larger version
ID:	905697   Click image for larger version
Old 03-17-2008, 08:44 AM
CESARSKYDIVER
Anyone more doing this fantastic plane???
Old 03-18-2008, 04:30 PM
Props4ever
ORIGINAL: CESARSKYDIVER
Hi,
Do you have plans on paper or just on CAD files?, i would be interested in getting plans from you and building one myself at slightly bigger wingspan with glow engines or small gassers like G20.
Regards
Old 05-11-2013, 09:27 AM
F86_SABRE
Any developments on this?
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
