Go Back  RCU Forums > RC Airplanes > Twin & Multi Engine RC Aircraft
Reload this Page >
kmp dc3 due november 30th i just ordered one
Twin & Multi Engine RC Aircraft Discuss the ins & outs of building & flying multi engine rc aircraft here.
Old 04-28-2010, 03:20 PM
  #126
scalenutz
Default RE: kmp d3 due november 30th i just ordered one
WOW, I asked a question about converting my C47 almost 2 years ago! I read your review and even though its too late for me I would like to see some pictures of your model. I finally settled on OS Engines and my model is still around and looks great.
Scalenutz
Old 06-07-2010, 08:14 PM
  #127
SWORDSN
My Feedback: (13)
What happened to this build?
Old 05-02-2012, 05:55 PM
  #128
robbie9859901
I've had this model for some time. I'm finally starting on it. I'm going to use two DLE 20's and Lado gear. Here are some pictures of mounting the engines. They are too long for the cowling. I have to cut out an opening in the firewall for the carbs. I made a prototype firewall out of plastic to make sure that everything would fit. I didn't want to cut anything prematurely.
ID:	1757998   Click image for larger version
ID:	1757999   Click image for larger version
ID:	1758000   Click image for larger version
Old 05-02-2012, 06:09 PM
  #129
kthmarks
Thanks for resurrecting this thread. This plane is definitely on my short list and I'm anxious to see how the 20's perform!
Old 05-03-2012, 03:16 AM
  #130
AncientCityFlyer
AncientCityFlyer's Avatar
I'm on board for this one. Been on another thread here on the C-47 build. Been working on mine for a year and a half. Just busy at work but slowley working on it. Mike
Old 05-05-2012, 03:09 PM
  #131
robbie9859901
Both engines installed and the gear works. I built a plywood ring to internally mount the cowlings. No screws on the outside. There is a You Tube video on this model with twin 20 gas motors on it.
ID:	1759203   Click image for larger version
Old 06-03-2012, 09:56 AM
  #132
robbie9859901
I've reached a major milestone. The wing is complete. The four flap servos, two aileron servos, two engine servos and the two Twin Sync magnetic pick-ups are installed and operational. I ended up changing the main gear a little. The main gear strut is attached to the actuator with two 4-40 screws that are threaded into the struts about .125". This bolt presses on a .25" steel shaft that has a small counter sink hole in it. I stripped two of the 4 bolts, trying to get things tighten up with no slop. I ended up cutting a slot and squeezing the strut to the .25" axle using a bolt and nut. Now it is solid as a rock. I can get you a picture or drawing if anyone is interested. I have attached a few pics.
ID:	1768575   Click image for larger version
ID:	1768576   Click image for larger version
Old 06-07-2012, 02:24 PM
  #133
robbie9859901
I'm building my DC-3 as a gun ship. I had Zotz decals make a few sets of decals in the correct sizes for this plane. They normally make them in 1/48th scale. I have a few sets extra, if anyone is interested.
Old 06-07-2012, 05:32 PM
  #134
smullis
My Feedback: (26)
Robbie9859901, I am also thinking of buying one of these planes.Are you using the ESM landing gear and I would like to see your mods on the landing gear if possible.I would also like for you to let me know when the maiden will be and if possible take a video. I want to see how scale it flies with the twin twenty's as far as full speed and cruise flying. I flew this plane as an engineer in Danang, Vietnam in 72&73.I was in a squadron called 362 Tews. Tews standing for tactical electronic warfare search.I love these old Gooney Birds.
Thanks, Steve Mullis
Old 06-07-2012, 05:51 PM
  #135
AncientCityFlyer
Robbie, I've been working on mine for quite a while now. Off & on for a little over a year. Work keeps me busy. Anyway I'm also doing mine as an AC-47. Here's a few pic's of mine. I was a flt. engineer on one in Nam 67-68
ID:	1770143   Click image for larger version
ID:	1770144   Click image for larger version
ID:	1770145   Click image for larger version
ID:	1770146   Click image for larger version
ID:	1770147   Click image for larger version
Old 06-07-2012, 05:55 PM
  #136
kthmarks
ORIGINAL: AncientCityFlyer
Outstanding! Would love to see.......MORE PLEASE!
Old 06-07-2012, 05:57 PM
  #137
robbie9859901
I'm using the ESM gear with the electric Lado retrac servos. No air. I hope this picture shows up well. You can see where the stock set screws go to hold the gear leg to the shaft. I cut a slot in the gear leg and drilled a hole to put in the bolt as shown. The gear leg is now solid on the actuating shaft. I'm sure that the .20's will be too much at full throttle, but that is what throttles are for. Scale takeoff and cruising will be at reduced throttle.
Old 06-24-2012, 02:19 PM
  #138
PirateKevin
I'm balancing my ESM DC-3 and I'm glad to get the proper 25% or 4" from leading edge. Only one question, My Giant scale balancer seems to set the plane on it inverted better than rightside up. Which way did you guys balance your planes?
Thanks to all in this thread for the info!
Kevin
Old 06-24-2012, 04:24 PM
  #139
smullis
My Feedback: (26)
Pirate Kevin, Hello, Being a model builder for over 45 years, you always balance a low wing plane inverted. If the wing is below the horizional center line of the fuse always balance the plane inverted. Also balance the plane with the gear retracted. Steve Mullis
Old 06-24-2012, 05:58 PM
  #140
AncientCityFlyer
Ditto what Steve said. When you get it balanced please let me know how much weight..if any, you needed in the nose. I've heard it takes a LOT in the nose for proper balance. Thanks Mike
Old 06-24-2012, 08:09 PM
  #141
PirateKevin
Thanks for the info. I'll have to re balance it, I did it with the gear down. I didnt weigh the bird shot but it's has to be 1 3/4 to 2 pounds
I'll rebalance and weigh how much it is. I put the CG right at 25% which is right at 4 inches
Kevin
Old 06-25-2012, 02:13 AM
  #142
AncientCityFlyer
The weight you needed sounds about right for this bird. It needs quite a bit from what I've found in a cuople of other threads on RCU. If you haven't found them. here's a link to them. Not too much more info but every little bit helps.
http://www.rcuniverse.com/forum/m_10...m.htm#10333006
http://www.rcuniverse.com/forum/m_70...tm.htm#7025866
Old 07-24-2012, 02:49 PM
  #143
BUGGS50
Hi everyone,
I'm building one of these also, Mine was a DELTA being converted to a WW2 C47, going slow but I need to have it done in time for Ames Iowa multifly Sept. 8th & 9th. I'm done painting and I'm now assembling. It shouldn't take to much longer. Hey AncientCityFlyer how's it going? I got to thank you for your help, I noticed on your bird that you cut one of the doors out. I cut both doors out had a hell of a time getting them to fit back in and they still don't fit perfect. I plan on dropping paratroopers but I'll see how thing balance out. I'll try to take some pictures and get them on here.
Bill
Old 07-24-2012, 04:16 PM
  #144
AncientCityFlyer
Bill, sounds good, looking forward to see your pic's. Mike
Old 07-31-2012, 07:26 AM
  #145
BUGGS50
I'm installing the retracts now and they seem too long. The plane seem's too high, dose anybody know what the distance is between the ground and the bottom of the wing on a real DC3?
Bill
Old 07-31-2012, 08:45 AM
  #146
AncientCityFlyer
As I recall ( long time ago) it seems the distance from the tip of the prop blade pointing straight down to the ground was about 42". Can't swear by it though. Mike
Old 07-31-2012, 02:06 PM
  #147
BUGGS50
Hi Mike,
Did yours seem long or did your plane seem high? also would like to know more about swiching to elecrtic retracts
Bill
Old 08-01-2012, 02:32 AM
  #148
AncientCityFlyer
It does sit a little higher than scale but not much I can do about it for now. I looked into elec. retracts through Ladro ( I think) and it would be about $500.00 for a pair.
Old 08-01-2012, 05:42 AM
  #149
robbie9859901
I got my lado retracts here: http://www.lado-tech.net/en/content/6-dealers
I believe that they were about $250 for the pair. There are pictures in the previous posts.
Old 08-02-2012, 05:07 PM
  #150
dkm
dkm's Avatar
I am about to start a DC3 build.
Was planning on fitting OS91fs for power, but now thinking
about using NGH GT17 two-stroke Petrol Model Aircraft Engines.
They are pumped and I can use smaller tanks, with 13x8 props.
