futaba FP-7UAF SUPER
MI
does anyone own one of these. I bought one for 100 it works fine but whats alarming is the large portion of the antenna unlocks and slides all the way down the case. when pulled up it locks into place. most radios ive seen had a screw in antenna on a lug. this is held on with a socket bolt. the antenna clicks into place and the radio works fine
RE: futaba FP-7UAF SUPER
I just looked at one that I never use, so I am not very familiar with it. There is no set screw visiable. The antenna just slides up and down, but seems a little loose.
there should be a small washer under that screw to keep the ant from pulling all they way out.all futaba computer tx on 72 mhz work about the same including my 9z.no problems
