NEW KMP 95" B-25
#1251
RE: NEW KMP 95
http://www.wingspanmodels.com/Produc...onics/ERS.html
This is the bombdrop I am using and I believe Eldher is also using this system. I have attached a photo of the bomb bay during construction.
#1252
CO
RE: NEW KMP 95
Yes, I use the WingSpan models bomb drop. It works GREAT. I can add more picts if needed.
I am not familiar with JC EVO engines, so no comment there. Given this is a twin, be sure to buy reliable engines.
I also use the Troy Built Models "Twin Sync" module to keep the engines in sync and provide protection if one engine fails.
#1253
My Feedback: (34)
RE: NEW KMP 95
Hey guys I have been reading throw this thread, and Im looking for a new B25
I had a Hanger 9 B25 electric with $350 worth of sound equipment that just did not do it for me, so I gave it to my bud at a kill deal, Traided for a new DLE20 and $100.
So I have a ESM 74in Corsair and I know how they build, I really like this one over the topflite as I hate moncoat.
But I have to ask are the ones comeing out now have all the problems that the first ones had solved? Ie droping wings?
Thanks Mike
Thanks Mike
#1254
RE: NEW KMP 95
They fixed the drooping wings. They are still not quite scale, which I believe is negative 3 degrees but it has been fixed from the originals. This is the best shot I have from the front.
#1255
CO
RE: NEW KMP 95
ORIGINAL: tevans55
For those interested in the history of the wing on the full scale B-25 ... read on.
The original production B-25 had a constant 3 degrees of dihedral from wing root to wing tip. During initial flight testing with the Nordon bomb sight stability problems developed. The bomb sight would correct the aircraft direction with the rudders. As this was done the B-25 would roll significantly from wing tip to wing tip in a "Dutch Roll" with a lateral side to side oscillation developing. Today we'd say the plane had severe yaw-roll coupling. The engineering team fixed the problem by reducing the height of the rudders and setting the dihedral angle of the outboard wing tips to *zero* degrees. The original plane was modified on site and continued testing. Some sources indicate that the first 10 B-25s were built with the constant dihedral, all of which were modified to the gull wing configuration. (Source "B-25 Mitchell, The Ultimate Look")
NOTE: this is not in the book, just my personal observations and basic geometry. The reason the wings appear to droop down ever so slightly is because the *top* of the wing does droop. The zero degree dihedral is set through the chord line of the wing. Proportionatly there is more wing above the chord line than below it. However these proportions become less as you move from the root of the wing to the tip. Hence the top serface of the wing goes down slightly. Attached is a drawing.
If you are a serious fan of the B-25 you will want to book I paraphrased above. This is a fantastic resource. 475 pages of the finest detail, drawing, and pictures. Including pictures of the original straight wing B-25!!
#1258
My Feedback: (34)
RE: NEW KMP 95
Hey guys I'm glad this bird is back in stock. I'm holding to have the funds on Monday.
Few ququestions I see some have flown this bird with DLE20 but I just saw a clip on YouTube of a guy with a pair of DLE 30s
I really like my birds over powered as we have a short run way.
Anyone done this yet?
also the ESM v3 retracts are out of stock. Did you guys like these retracts
are there any Robart or another brand retracts you recommend?
#1259
RE: NEW KMP 95
mikes68charger-
I have flown this plane at 33 lbs+ with DLE 20's and it is over powered. On the maiden it took off at about a 45 degree climb until I dialed in some down elevator. My spotter and I were amazed that it had the power to climblike that and not stall. The 20's are PLENTY of engine for this plane and fit really nicely into the alotted space.
Part of the reason my plane is heavy is that I added Robart wheels and brakes. My retracts are from Century Jet and are the prototypes that are a drop in fit for this plane. I also increased the wheel size to a more scale 5.5" diameter. Nose wheel is a Sullivan wheel. Here is a photo of the retracts, wheels and brakes. They are well built and very stout. Hope this helps.
#1260
CO
RE: NEW KMP 95
ORIGINAL: mikes68charger
I run Saito 150s (24cc) and the plane has lots of power (and my field elevation is 5000', so I loose about 15% of the engine's output). My concern with DLE 30s would be vibration damage over time. The plane was not designed around this kind of power and you might suffer stress fractures over time.
#1262
RE: NEW KMP 95
Unfortunately I have a set of used Century Jet retracts for this bird. I had an engine flame out and lost the plane. The retracts were not damaged in the crash. I fly with Eldher13 so I could get him to verify the condition. The mains are 1/2" and the nosewheel is 5/8". If you're interested let me know and we can hook up off line.
#1263
CO
RE: NEW KMP 95
Wich Robart gear did you use?
- 635RS 90 Degree Heavy Duty Mains
- Robart Straight RoboStrut 1/2"
- Disc Brakes For 4" - 4 1/2" Brake Ready Aluminum Wheels (pr.) (pt# 140)
- 641RS nose wheel retract, 110 degree
- RoboStrut 440/661 (7/16") for the nose wheel
- I am using the original ESM nose wheel
It requires only a minimal amount of work to get the mains to fit. I'll upload some picts.
#1264
CO
RE: NEW KMP 95
ORIGINAL: Eldher
I have installed the folling Robart gear:
- Robart Straight RoboStrut 1/2''
- Disc Brakes For 4'' - 4 1/2'' Brake Ready Aluminum Wheels (pr.) (pt# 140)
- RoboStrut 440/661 (7/16'') for the nose wheel
#1265
My Feedback: (34)
RE: NEW KMP 95
Wow thanks guys for the info I decied to get the retracts from Bumsteer So I got that covered.
Im placeing my order on Friday, Im very excited
the only issue I got left is to figure ot the motor issues.
I got a DLE20 and DLE30 sitting on the shelf looking for a home, Im think more of the DLE30 as I will be able to run a more thicker and scale looking prop and I love exstra power.
What is the longest prop you can run before you have ground contact or plane contact issues?
My Hanger 9 B25 that I gave to my buddy was electric at 22 pounds with sound system could still do non scale loops wich made if fun.
I See that Bumsteer used Evolution 26cc motors wich are as strong as DLE30's as far as I know.
But most I talk to say a DLE 20 will be great.
I like over power, I got a DLE55RA in My 74in 30CC ESM Corsair and Love it. But to be 100% honest its only a tad faster than my other 72in war birds withDLE30's but I wanted to run a scale prop.
Im reading throw this long thread, dose any one eles have any motor input?
Thanks Mike
#1267
RE: NEW KMP 95
I am using Wingspan Models 50 calibre and gun belt in the nose of mine and a Dynamic Balsa nose turret. Wingspan's gun is all metal the belt clips are metal and the shells are brass (I think). (Of course the tail turret guns of my Doolittle plane are wood broomsticks!) Here are some gun and turret shots. I also included a shot with a 16" 3 blade prop. You could do a 17" but I think you might have clearance problems above that.
#1269
My Feedback: (34)
RE: NEW KMP 95
Wow I mine just showed up yesterday. The box was huge!
So I decied To get 2 ASP 1.80 4c at $230 each + the $150 each to convert them to gas (Nitro makes my skin break out)
With gas power will be down a little but should be about the same as the 1.50 4c.
I got a really good deal on a Spacewalker 2 that I will be useing as a test platform to make sure the motors are running the way they should
So question, Im readding about the wings breaking in the center, I just got a new one from the new shippment, do you think they may be dif?
Is there a way to strenthen the center section up with out cutting the skin off? I would like to fix it before the first flight.
ThanksMike
ThanksMike
#1270
CO
RE: NEW KMP 95
Thanks Mike
Thanks Mike
The best approach is to remove the bottom sheeting and strengthen the inside of the wing. I realize that this is not what you want to do, but it will definitely do the job. You can look here to see what I did to my wing: http://www.rcuniverse.com/forum/fb.asp?m=9047984
I can not think of a good approach to strengthen the wing without removing the sheeting. In any case you would have to remove the covering ... so why not just go all the way and remove the sheeting too.
#1271
RE: NEW KMP 95
Very interesting thread...
I will get mine in a few days and looking for power system...
Electric... probably a pair of Plettenberg 370/40/A3 I have... 1500W or 2.0HP each... should be enough ?
10s a123 packs...
Objective: less than 12kg.
10s a123 packs...
#1272
CO
RE: NEW KMP 95
ORIGINAL: ramboman
10s a123 packs...
10s a123 packs...
#1275
RE: NEW KMP 95
Some do...so dont. Ive never been able to get mine to function properly, but I probably didnt get it setup right. There are several that fly their b-25's(of any brand) without it and rely on tuning the motors.
Me? Well....I keep the onboard glow units turned on throughtout the entire throttle range so a motor going dead shouldnt happen(although I currently have 3 cyl radials and those are a problem in and of themselves keeping all cyl's firing)
