Differential thrust/motor control?
Greetings from a new airplane owner!
I have just purchased and assembled a Multiplex Twin Star 2. I have mounted a couple of 2822 size 1400KV BL motors and I'm considering to mix the rudder signal into the motors for several reasons: 1) Better steering on taxiway 2) Possibility to balance non-identical ESCs 3) Better air control or possibility to ditch rudder servo alltogether. I'm pretty new to fixed wing RC aircrafts, but I have build and flow an rc quadrocopter, several rc cars (driven, not flown), and I'm a certified privat pilot (PPL). I don't know if any of that will do me any good with respect to the Twin Starhttp://www.rcuniverse.com/forum/js/f...spinnyeyes.gif So I'm seeking advice: a) Should I drop the diff motor control idea? b) What would be the easiest way to program my Graupner MX16s for that? Currently, I run the second ESC on a separate channel, no 8 set up as "slave" of ch 1. I can't get the mixer to work on the slave... c) Would 2S or 3S LiPo be the safest newbie set-up? Inputs will be appreciated Edit 4. Jan: I have solved the diff trust mixing (using the 3 free mixers), and I have read elsewhere that the diff thrust is commonly used, so I'll stick to that. Cracking the graupner mix-functionality, I also went for 50% diff-ailerons, flaperons, and 20% aileron-rudder mixing. Furthermore, straigthening the motor mounts, I fit and balanced 8x3.8 cw/ccw props which seems to provide a lot of push at 2S LiPo, so I think I'll stay with that for now. It keeps the weight down to 910gr RTF w battery, and I guess that low weight must also add a a benefit if crashing or landing hard.... |
| All times are GMT -8. The time now is 04:15 PM. |
