4 motor ugly Stik
1 Attachment(s)
<span style="font-family: arial, helvetica, sans-serif; font-size: 15px;">.40-size Easy Stik Series ARF from valuehobby</span><br style="font-family: arial, helvetica, sans-serif; font-size: 15px;" /><span style="font-family: arial, helvetica, sans-serif; font-size: 15px;">4 2212 930KV motors 4-20 Amp ESC'S running on a 4000mah 4 cell</span><br style="font-family: arial, helvetica, sans-serif; font-size: 15px;" /><span style="font-family: arial, helvetica, sans-serif; font-size: 15px;">with differential thrust useing 8x6 apc props</span>
RE: 4 motor ugly Stik
Why? Because we can! Nice bird!
The differential thrust feature ought to be interesting. How fast is the roll rate? Nice plane. </p> |
<font face="arial, helvetica, sans-serif"><span style="font-size: 15px;">the differential thrust was setup for ground control because</span><span style="font-size: 15.199999809265137px;">the tale wheel is not sterilable</span></font>
<font face="arial, helvetica, sans-serif"><span style="font-size: 15px;">have not flown it still building it too cold here in new york to go flying</span></font><br style="font-family: arial, helvetica, sans-serif; font-size: 15px;" /><span style="font-family: arial, helvetica, sans-serif; font-size: 15px;">got to glue the motor mounts on the wing</span><br style="font-family: arial, helvetica, sans-serif; font-size: 15px;" /><span style="font-family: arial, helvetica, sans-serif; font-size: 15px;">but its too cold need too open the window so i wont die from the epoxy smell</span><br style="font-family: arial, helvetica, sans-serif; font-size: 15px;" /><span style="font-family: arial, helvetica, sans-serif; font-size: 15px;">just stuck the wing on to see what it will look like when done</span><br style="font-family: arial, helvetica, sans-serif; font-size: 15px;" /><span style="font-family: arial, helvetica, sans-serif; font-size: 15px;">all the wired up and ready to go <br type="_moz" /></span> |
1 Attachment(s)
Should work better than my attempt. All that motor weight up high made it very difficult to fly. Those four .25 motors were heavy and all the weight above the CG by quite a bit made it very heavily loaded.
ORIGINAL: evan-RCU Should work better than my attempt. All that motor weight up high made it very difficult to fly. have flown a twin but it was a lite foamy I know its not going roll quick what was your plane doing that made difficult to fly and do you have any larger photos of it to post here I wound like to see more if it |
1 Attachment(s)
Here's a Stik I did with three OS 28's.
1 Attachment(s)
Not a Stick, but I put six engines on a Big Apple pattern bird. Not yet flown.
