Identify this plane please
I purchased this kit built plane that hasn't been flown. Can anyone tell me what model it is and what servos would be the minimum required? The wingspan is approximately 70" and the length 53". I have some Futaba 3003 and 3004 servos but the torque is fairly low. I believe it has twin OS .46's. It also has retracts. This is my first plane with retracts so I could use some hints on setting that up also. It already has a Robart air tank and lines plumbed.
http://http://i199.photobucket.com/albums/a...e/IMAG2256.jpg |
Hi!
It's a semi scale model of a Cessna 310. Engines suitable for it is pair of .25. With two .46 it will fly too fast and be too heavy! |
I would probably stick two .36 in it if I were building it, but if it already has 46's in it then I guess you will see just how it flies. I don't know anything about air retracts but do know that the newer electric retracts are the easiest way to add retracts to a plane for me anyway. From the picture it looks like it has flaps so that will let you slow down a little bit for landing.
| All times are GMT -8. The time now is 09:48 AM. |
