*Flight of the Phoenix*
This is a build I did elsewhere.. Was suggested I bring it here..
Sooo,, here it is... Ok,, So I was recently asked about a project I have had on the back burner for a while.. So I thought I would put it out for you people to scrutinize.. I decided to call this plane the 'PHOENIX' in reference to the old movie about the plane that crashed and was sorta rebuilt to fly again to save the people who remained.. Life for the Phoenix started out as a Hobbico ARF, the Twinstar.. I aquired the bare airframe less anything that was not balsa.. No fuel tanks, no landing gear, nothing.. Just a well used and abused bare airframe.. Battle tested,, ohhh yeahhh... Having done a couple of Twinstars in past and knowing what I would like to see different I decided to make those changes on this one.. As silly as it may seem I wanted to keep a close resemblance to the 'ARF look'.. Some of the changes I wanted were to loose the blunt nose, increase fuel capacity, increase rudder authority, increase of speed ability, and loose some of the 'cookie cutter' look... I know, sounds ambigous, keep ARF look but make less cookie cutter look.. But it isn't really... So, the basic plan is to extend the nacelles to accommodate larger fuel tanks and be able to set motors at zero downthrust and at zero outthrust.. Rather than increase rudder size move the rudder hinge line forward which is more effective than making a larger surface.. Then extend the nose and make more pointed... Part of the nose extension was to also move nose gear forward as well just for the heck of it.. Additionally the elevator was made anew and was enlarged slightly towards the center leaving the ends same size.. With things being extend forward there is a major shift in the CG (center of gravity) so it needs to be compensated for.. I prefer not to add weight for balance so this necessitates moving some items needed for a plane towards the read.. A couple of changes along these lines are make a battery box behind the trailing edge of the wing and move elevator servo to rear of plane from the center area.. Having done some of these changes it still up'd the total plane weight so some lightening was done along the way.. Then there also needs to be access to things as nose gear in case adjustment is ever needed, access to battery, and access to the rear mounted elevator servo.. Hatches were made to facilitate access these things.. Ok, lets take a peak at what we have going on now... ( questions and comments welcomed) |
RE: *Flight of the Phoenix*
1 Attachment(s)
Here is a shot of the bare nose of the Phoenix..
The red line shows where the original plastic nose would be.. The line where the extension joins the fuse is where the nose gear used to be.. As noticed the nose gear is slanted now where prior it was not.. |
1 Attachment(s)
This is my favorite control surface... The RUDDER ..
There has been approx 15% of the vertical removed from the front and the hinge line has been moved forward.. Of course, this means the rudder was extended forward as well and as seen a counter balance incorporated to reduce servo load.. The rudder is attached via three Robart pin hinges.. In this pix covering with MonoKote has been started .. |
1 Attachment(s)
Here is a pix of the hatch to access the nose gear steering so
adjustments can be done when needed.. It has wooden pins in front and attached with button heads in the rear as shown.. The large looking gaps are for room after the bottom and the hatch are covered they will fit well.. |
1 Attachment(s)
Here is a pix of the hatch for the battery box..
The rear has hardwood pins into the rear wall of box and the front is attached by buttonhead screws going into hardwood blocks.. This is in case of a possible hard landing.. There is a hole in the front wall of the box at the top for the power wire to exit.. This location was chosen so to be sure the wire does not interfer with the aileron linkage.. Helps to plan ahead.. ;) |
1 Attachment(s)
The elevator servo is mounted on cross blocks which are
attached to lite ply that was added to that area inside the fuselage.. The servo was installed into the rear of the fuselage to help shift some weight towards the rear of the plane.. An additional benefit of doing this is having shorter linkage so less likely for linkage to flex under load.. It also allows the linkage to be totally inside the fuselage so it can not be seen.. In order to access it for adjustments, to get to servo arm, attach linkage, or to even replace if ever needed the servo there is a hatch on bottom of fuselage as shown.. This is mounted with two light wood dowel pins and has a single buttonhead screw attaching it to fuselage.. |
1 Attachment(s)
Here is a basic overview of where what is..
The red line shows size and location of the battery box.. The green shows where the elevator servo is located.. And the blue shows the oringinal size of the rudder in relation to what it is now.. The orange show approx how much was removed from the vertical fin... The large holes showing were made mostly for access to the steering and rudder ny-rod installation with the added benefit of less airframe weight.. |
1 Attachment(s)
Now lets the landing gear as it will be necessary to do so
balancing of the plane can be done.. As I didn't get the original landing gear had to make it.. Not hard to do.. Just get some 5/32 K&S wire stock from your LHS and bend away.. First set desired height.. Make sure there is prop clearence.. As the nose gear was already made I used it for the basis of where the height would be plus I wanted to allow for a 12" prop.. Here is one side done and a wire stock to make the other side.. 1- Just put in vise, bend, then hammer corner to make it less of a radius.. 2- Now for the second bend ... With each bend do a trial fit to be sure it does fit.. 3- Making the second gear is easier as basically copy the first one.. Even so, do a fit just to be sure... 4-And here we are, all the bends and cuts done... Now that wasn't hard,, was it ... :D And then mounting hardware.. The wheels have to be mounted to our newly made landing gear.. Here we see a nylon collar from local Ace Hardware to keep the wheel from binding on the small radius of the bend.. The brass collar with set screw from Ace will hold the wheel from coming off the landing gear.. And here we are, babys first step... :D So after spending a little time and very little funds we have made the main landing gear for the Phoenix.. |
1 Attachment(s)
We know we will be adding more power than what the plane
was designed for and knowing the horizonal of the original TwinStar is a weak point on the plane we have modified it to make it stronger and more effective.. The pink line shows where the original hinge line was.. Just making the elevator a larger surface does not really do a lot.. But to make it larger while reducing the horizonal area by same amount makes elevator more effective.. When the hinge line was cut in the trailing edge was replaced with dense balsa.. The forward area of the horizonal also has had dense balsa cut in to strenghten it so that it does not fold or flutter.. Robart pin hinges were used to secure elevator to horizonal and to allow elevator to deflect up or down to about 50 degrees.. Will it ever see a 50 degree deflection,, I highly doubt it.. ;) |
1 Attachment(s)
Now we are going to attack the wing, the final frontier ... :)
As depicted in this picture is how the original nacelle looks and how the modified nacelle looks.. The red arrows show the original lenght of the nacelles... And the orange arrows show where the motor mounting rails are pin'd ... The new firewall is a lot thinner as can be seen here.. As the motor will be mounted on 'rails' there is no need for a motor mount and no need for the heavy duty firewall.. Now the firewall is basically a thin plywood former within the nacelle ... The 'forward extensions' are tight grain balsa and the motor mounting rails are attached in a way to make the extensions stronger.. More of an insurance thing as the motors will not be mounted that far forward on the rails.. |
1 Attachment(s)
After doing the mods to the nacelles I made a facia out of 3/32
balsa to put over the outter side to both add some strenght and make it look better by no chance of any work showing thru the covering.. While working on the modified nacelles the original balsa facia was sanded rather thin so adding a new facia over the original one that is now a lot thinner will strenghten some.. Thin CA could have been used as it would have soaked into both pieces of wood however I elected to use Titebond even tho it takes longer to dry.. This was done as the Titebond is every bit as strong as CA in this application plus allows for a little flex, not to mention less cost.. There is no weight difference.. As can be seen with the outter facia there is no chance of any work showing after it is covered... Then we have a pic of the finished nacelle with the 10oz fuel tank installed... Yes, the rubber bands stay on fuel tank.. Additionally there will be a piece of soft foam on top of tank to insure it stays put as the nacelle cover is rounded and could allow fuel tank to move around.. |
1 Attachment(s)
Ok,, so lets flip the wing over and see what has happened
down there... Opps,, there is a dang 22x10 Zinger prop in this pic... What in the heck does a 22X10 prop have to do this the Phoenix you ask.... Welll,, lemme tell you.. The original Twinstar uses a two part block for the main landing gear.. The long flat part which holds the gear to wing and the vertical block to keep it from rotating.. In many cases the vertical block splits or breaks off.. So in giving this some thought I was wondering what wood I could use that was strong as heck but not as heavy as a brick... Taa Daaa... A Zinger prop comes to the rescue... The pic isn't real clear but the vertical block is a very snug fit to the long horizonal gear block and it is also has epoxy holding it to the rib which is lite ply.. (disclaimer: There were no live or usable Zinger props used in the making of this segment ) |
1 Attachment(s)
The original Twinstar has decent axial control, or better put,
decent aileron control.. but that is about it,,*decent*... As I wanted more axial control, very effective flaps,, and the original ailerons are left uncovered on the ends they soak up fuel and become nasty,, I decided to slap on a larger aileron as shown in first pic .. In order to have aileron and flaps (flaperons) seperate servos have to be used... To do this the centered mounted single servo mount was removed and lite ply was used to make a new mounting for two servos.. Not shown int his pic but to be added later is a balsa spacer between the two servos.. This is for more of a 'wire loom' to keep two throttle and two aileron servo wires from getting into the aileron linkage... They were mounted in stock location so to hide the servos... The aileron servos are back further than the original so there will be less linkage length so less chance of linkage flex.. Where the original servo was on the CG both or the replacements will be behind the CG... Remember, we have larger fuel tanks and larger motors in front og CG that need to be compensated for,, so rather than add weight to balance lets just move items during construction to compensate.:D |
1 Attachment(s)
In this segment we shall do a little covering of the wing now that
we have all the wood work completed... I prefer to install the CA hinges prior to covering onto the wing so I can make sure the hinge is thourghly glued in.. Thin CA can be put on the outside and from within the inner wing area to insure this.. Nothing like having a hinge pull out at high speed.. [X(] As we want to match the way we cover the tail in the beginning of this series here is a pic of the basic look we are after.. :eek: Ok,, as I dislike having seams when I cover I try to use one piece in as much of an area as possible.. Now true, there are sometimes that having seams just can't be avoided, however, this is not one of those times.. So measure out the piece of covering needed.. In this pic it shows the basic piece and with the first cutout for the nacelle.. Carefull alignment is required so not to make the nacele hole too large which would require 'filler' pieces (seams) nor too small or the overlap will show.. When the nacelles were covered there was a small overrun left going onto the wing surface.. So when the wing is covered the cutout needs to only be to the side of the nacelle.. Is it worth all this trouble... Only you can answer that for yourself.. For me, welp.. Lets see.... The tighter the covering is kept during covering the less shrinking will be required and the more opportunity for future shrinking of the covering as needed in time with age and use.. |
1 Attachment(s)
So now the added trim/design is ironed on.. Yeahhh...
After getting all edges trimed and ironed down, making sure all joining seams are totally sealed by lightly running iron over them then a heat gun can be used to shrink as desired.. Because the covering was kept tight during the covering process very little shrinking with the heat gun was required... :D |
1 Attachment(s)
Here we can see the wing, allll done... Took a while but came
out rather decent if I say so myself... :eek: As this is one of the original Twinstars that had plastic tips and I wanted to keep the ARF type look, the tips were put back on.. Tips are on, ailerons are secure and blended to match the tips,, nacelles painted and fuel coated and all covering done.. So its about time to toss on some motors,, huh... [>:] |
1 Attachment(s)
Here the design can be seen..
Try'd to match it out to how the tail was done.. The one dark green strip will be carried over into the fuse which will be covered in another segment.. |
1 Attachment(s)
Covering the fuselage of the PHOENIX...
I lost the pics showing so will text it to give you the idea how we got to where we are now.. First, we laid covering over a side, ironed it on for about three inches at the tail area.. Then we pull covering very tight towards the front.. The tighter the covering is kept the less heat gun use required and better it comes out.. While pulling it to the front very tightly about an inch or so is ironed down.. hen the top is pulled out from fuse as iron is run along edge to hold it down and same is done for the bottom, keeping it as tight as possible.. Trim off excess from top and bottom leaving an ample amount of covering so we can wrap the nose.. Now for the fun part.. Pull the covering extremely tight around the curve of the nose towards the other side running iron over the center to hold it.. Now trim off excess and iron down edges.. There needs not to be much to hold it so only an inch <approx> was wrapped around the nose.. Now cover the same on other side leaving the nose section undone for now.. Take some 220 sand paper and lightly sand the piece of covering from the other side to knock down any of the 'creases' and to get a rough surface.. Then pull final piece of covering around tightly and iron on, do final trim, and then work out the edges so there are no rough edges left.. Now go take a break 'cuz this was nerve racking. [:@] Ok,, break over.. Back to work, Bucky.. Time to attack the top.. Again we will lay out the covering and iron down a couple inches in the tail area first.. Then pull the covering extremely tight while running free hand in a forward motion to insure it is very tight.. Tack iron it to the windshield area and work way down entire windshield.. Then pull remainder across the front/top ironing it down on the end of nose.. Do initial trim of the excess from the entire top covering but leave a decent amount at the nose area.. As part of the bottom to the nose gear will be covered with this material go ahead and wrap it around nose and pull tight over bottom area to be covered, leaving 'nose ends' undone.. Do the final ironing of this area and do trim.. This piece will be wrapping over the two side pieces that we have overlapped and sanded already.. This will totally lock all the covering together so not to come undone.. Take the covering that is remaining, pull outward tightly and iron down, working all wrinkles out, on both sides.. Now do final trim, than finish working any wrinkles out of the edges.. Doing compound curves as this nose does make for extra scrap but is worth it with the final result being a clean smooth finish... |
1 Attachment(s)
So you thought you were alll done covering the fuselage, huh...
Welp, the bottom still needs to be covered.. The bottom is going to be done in white to keep with the theme of the design.. This will be a little easier than what was already done .. Lay out the covering again starting at the tail and working forward keeping it very tight... Part of this piece will be going over an open bay where the elevator servo is accessed from and also over the battery box.. After securing it at the forward most part pull out covering from sides and run iron over edge to hold sides.. Lay up and do trimming to where color separation is to be.. Trim and iron down of course working out all wrinkles.. Sometimes a wrinkle may get ironed in.. How in the heck does one get it out.. I found by using a piece of thin balsa as a heat shield laid up to the line on the new piece that a heat gun can be used with caution so that the original covering is not heated to any appreciable extent.. Just gun it, then iron it out, wrinkle free covering... Time to do the frontal area, bottom.. This is a little tricky as again have to deal with compound curves, and, getting a color line on the side.. Remembering I do not care for same color seaming.. I started at the rear are where leading edge of wing sits, ironed in down for about an inch, then pulled it very tight to the front and tacking it down at the rear of the nose gear opening.. After getting the piece tacked down had to do cuts to keep covering from wrinkling over itself on the frontal curve as it is brought up onto the sides for the color trim.. Iron it down, and running gun over it where needed to get out wrinkles making sure to run covering along entire side of nose gear opening.. Now the openings are cut out and covering is folded into the openings after trimming off excess.. Now for the hard part.... Covering the simple flat hatch covers.. Waiting to do this till after the bottom is done the scrape from doing the bottom can be used to do the hatches.. Now that the basic covering / colors have been applied time to do the trim pieces.. First the windshield / windows are laid down.. This gives a good idea where and how to lay out the coloring trim to match wings and tail.. The windshield and windows were done with black monokote scraps.. [8D] |
1 Attachment(s)
But after a long time doing,
all the covering and trim is done.. DONE, I tell you .... [sm=bananahead.gif] So here is the PHOENIX, ready for hardware installs.. |
1 Attachment(s)
Installed the motors, did throttle linkage and did
the exhaust anodised green ... To be totally different I mounted Tiger Shark .52 's ... Zero outthrust and about 1½ downthrust... Currently mounted are 10x6 Master Airscrew three blade props ... Ought to be fun,, .52's on a .25 size plane,, huh... [sm=spinnyeyes.gif] Made nacelle covers out of fiberglass.. Then painted white.. |
1 Attachment(s)
As I spend over a year doing this on and off.. I did take it with me to the Multi Meet
in McDonough Ga this past summer <06/2005>.. That was the first time I had even fired up the motors... However, gremlins prevented it from taking to the air at that time.. Here are some pics of the Phoenix and current stock Twinstar... |
During the time doing this project,, with many interuptions,, the one question
has always been.. " When will it fly"... Welp,, kidz.. On 11/11/05 it took to the air... Yup.. I *finally* flew the Phoenix... :D:D:D:D I even took some pics... However,, being a cloudy day, flying off a grass field, and starting to get dark,, the pics were not so good.. So I will do more another time... Take off was in an instant... Was a little squirrly,, got it under control,, and just started to trim it out when one motor died.. CRAP !!! Much to my surprize,, wasn't as bad as I thought it would be given zero out thrust and being highly over powered...[>:] If it would not have been so windy I probably would have continued to fly it on one motor but I took the easy way out,, Yes, I brought it down.. So as short of a flight as it may have been,, *FINALLY*,, the title of this thread is true... The FLIGHT of the Phoenix... [8D];):D |
Well, Robby, since your first post about this project was made "Over There" on January 16, 2004, all I can say is
It is Effing Well Time !!! Bill. |
Hey, I remember that site. It's McDonough, GA.
Can't wait until next year. Flaps and I are planning some new twins for it. |
| All times are GMT -8. The time now is 04:17 AM. |
