P-38 gear door problem
Guys I'm just about done with my wing P-38 and I've ran into a little pickle. I just can't quite figure out how to hinge the nose wheel gear door. As you all know it is curved so do I use two or three hinges. Should I also make stand off blocks for the hinges. I already know what I'm going to do to closes them just want to get the hinge rite.
