RCU Forums
-   Twin & Multi Engine RC Aircraft (https://www.rcuniverse.com/forum/twin-multi-engine-rc-aircraft-192/)
-   -   Twin Engine Trainer (https://www.rcuniverse.com/forum/twin-multi-engine-rc-aircraft-192/746459-twin-engine-trainer.html)
Tree Top Thrasher 05-05-2003 01:41 PM
Twin Engine Trainer
Hey guys, I`m ready to start looking for a twin engine trainer, any suggestions on whats good out there, Also engine recomendations would be appreciated.
crashnfix 05-05-2003 09:54 PM
Twin Engine Trainer
1 Attachment(s)
Anthony
There is only one good one! The Twin Air from NE Aerodynamics.
http://ne-aero.com/
I finished mine a month or so ago, had "Flyfalcons" test fly it a couple times for me. Flys smooth and easy. Had an engine out at about 2/3 throttle. The only way you would know it was by the sound. After a few more flights on my single trainer I'm going to give it a go.
The kit cost $155.00 shipped. The instructions are a little vague for the less experienced builder, but John Marien at NE was super about getting back to me with answers to my dumb questions. I built it straight with no changes. Even copied his color scheme.
John recommends .45s but I went with a couple of used OS .40 FPs I picked up on ebay. Ample power for a trainer. Should I get bored with this, my Duellist 2-40 should be finished. After that, I'll start on my Duellist 2-60.
Here's a pic.
Tree Top Thrasher 05-05-2003 11:07 PM
Twin Engine Trainer
Thanks for the info Crash, I`ll check it out
Tree Top Thrasher 05-05-2003 11:40 PM
Twin Engine Trainer
I checked it out Crash, I did notice something I`d like to ask you about I saw a 3 bladed prop on yours and the one at ne-aero has a two bladed prop on it, What is the significance of that?
crashnfix 05-05-2003 11:51 PM
Twin Engine Trainer
Nothing special, just preference. With 3 blades, you get more ground clearance which helps a little on grass. Besides I think they look better. Those are 9x6s.
Tree Top Thrasher 05-06-2003 12:12 AM
Twin Engine Trainer
I think they look better too, Thanks again
William Robison 05-08-2003 03:38 AM
Twin Engine Trainer
JohnnyCrash:
Weren't you a country singer at one time? Haw.
Glad you're happy with the TA-45. I have 40FPs on mine also. And as you can probably guess, three bladed props.
Bill.
rcnats 05-08-2003 01:13 PM
Check this out
Tree Top,
I have a Hobbico Twinstar that's almost ready to cover, 2 40 size enignes (one still NIB). Yours for $325 shipped. I have a new set of B&D pneumatic 3 gear retracts to really set your twin apart for an extra $50.00. Let me know. Thanks.
*rcnats*
Tree Top Thrasher 05-08-2003 04:56 PM
Twin Engine Trainer
Actually, I was thinking of putting a couple of Saito 30 4 strokes on it. ZOOM ZOOM
rcnats 05-08-2003 06:04 PM
Sounds Good
Either way it'll certainly move out! :D Let me know if you're interested.
*rcnats*
nchrome 05-10-2003 04:23 PM
Twin Engine Trainer
Well I did a little kit bashing. I took a Tower Voyager and converted it to a twin and so far it is looking pretty good. I'm using two OS 26 four strokers on mine and I think it will handle them just fine. I also used two GWS micro servos for the throttles. Don't realy need a standard servo for the throttle plus it helps on the weight. I also have an A-26-B (converted to a bomber) with TT40s on it and it flys like scale except for the take offs it litterly jumps off the ground. So I figured that it needed an extra inch extension on the nose wheel should help it out quite a bit.
