Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Unusual R/C
Reload this Page >
Dornier 24 ground effect 3.7m wing span
Unusual R/C Discuss Airships, Blimps, LTA, VTOL, Ground Effect Vehicles, Hovercaft and more.
Old 04-16-2020, 11:33 PM
hickeysdownunder
Default Dornier 24 ground effect 3.7m wing span
I am using 3 DLE 20cc engines and am trying to work out how big a battery to run the 3 ignition units . Working voltage is 4.8 to 8.4 V .
This is the first time using Gas engines my last model was a converted chainsaw motor and a tooth belt to the prop shaft on a Do 18.
Any help would be appreciated.
Old 09-25-2020, 08:56 PM
Orionsmace67
1 2000mah LIFE per ignition. 1 5000mah 7.2v for all 3 both will last several flights. Calculate resistance and voltage drop with 7.2v + _ 6v
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
