Gorgeous White Drone Walkera TALI H500 GPS FPV Drone RC Hexacopter RTF
Have played quite a few quadcopters and hexacopters, but this one really drives me crazy from both the appearance and inner features including the perfect one-stop FPV solution, pro level Gopro Aerial platform and super long flight time up to 25 minutes.
The perfect one-stop Aerial video & FPV solution
Control all aspects of flight with the 12CH FPV radio Pro level 3 axis brushless gimbal and HD camera (iLook+), so stable that I don’t need to worry about the shacking shooting at all.
12 channels FPV radio
Large 5" monitor with real time 5.8g video On Screen Data, real time telemetry of battery voltage, temperature and GPS data which completely ensure safe flight.
iLook+ HD Camera
Aerial action camera, high resolution with13 mega pix stills / 1080p 30fps video and 5.8g video downlink build in.
G-3D Brushless Gimbal
Easy to operate,stabilized camera platform which support Gopro & iLook series cameras
Super Long Flight time of up to 25 minutes
Advanced high-capacity 22.2V 5400mAh Lipo-battery build in, battery charge status monitoring promote safe and convenient flight operations.
GPS Position Hold
New GPS flight control system featuring more accurate flight and GPS position hold
Hyper IOC function
The new advanced Intelligent Orientation Control, the H500 can start and fly in any orientation
completely solving "loss of orientation" problems for pilot.
Object round flight
The h500 can circle a GPS waypoint
One key back home
Support the "one key back to starting point" function during flying
Failsafe Return to home
Advanced RTH protects the aircraft in case of loss of signal control, the H500 will automatically attempt to return to its starting position for a safe landing. Advanced GPS systems protect it all.
[TR]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[TD]
[TD]
[TD]
[/TR]
[TR]
[TD]
[TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
iLook+ HD Camera
GPS Position Hold
Hyper IOC function
Object round flight
One key back home
DEVO F12E Features:
•Collected 2.4Ghz control system with 5.8Ghz image transmission function
•5.8Ghz real-time video display
•Professional 12 channels FPV radio
•Apply to multi-rotor、helicopter 、airplane、glider
•Smooth and exquisite four bearing rocker handle design
•Innovative profile cater to aerial photography
•USB upgrade online
•Skidproof pattern design fulfills comfortable handle
•Open battery compartment design support 7.4v ~11.1v Lipo battery
•CVBS video signal output supported
•5.8Ghz video signal input supported
•Support 32 channel to receive 5.8Ghz real-time image
DEVO F12E Specification:
[TABLE="width: 700"]•Collected 2.4Ghz control system with 5.8Ghz image transmission function
•USB upgrade online
[TR]
[TD]
Encoder:
[/TD][TD]
12-channel micro computer system
[/TD][TD]
Frequency:
[/TD][TD]
2.4GHz DSSS
[/TD][/TR]
[TR]
[TD]
Output power:
[/TD][TD]
≤100mW
[/TD][TD]
Radio distance:
[/TD][TD]
≧1KM
[/TD][/TR]
[TR]
[TD]
5.8Ghz video distance:
[/TD][TD]
0.3-2KM( up to transmitter)
[/TD][TD]
Image frequency:
[/TD][TD]
32 points
[/TD][/TR]
[TR]
[TD]
Frequency domain:
[/TD][TD]
5645MHz~5945MHz
[/TD][TD]
Drain current:
[/TD][TD]
≤200mA ( on 100mW)
[/TD][/TR]
[TR]
[TD]
Stand-by time:
[/TD][TD]
6~12hs
[/TD][TD]
Supported battery:
[/TD][TD]
7.4v or 11.v 1600-3000mah lipo battery, NiMH 8X1.2V 1600-3000mAh or 8 pcs of 1.5v dry battery
[/TD][/TR]
[TR]
[TD]
Output pulse:
[/TD][TD]
1000—2000us(1500 Neutral)
[/TD][TD]
[TD]
[/TR]
[/TABLE]
