Hobbico Lithium Volt Meter Discontinued
Does anyone know why the neat little Hobbico Lithium Volt Meter was discontinued? Ihave one and have been using it apparently successfully for about a year, and wanted to get a couple more for flight box, etc.
Couldn't find them anywhere online and finally emailed Hobbico. They replied simply that the LVM had been discontinued. Was there a problem with them. Am working with unreliable readings when I use the lttle meter? Just wondered. If anyone knows the story I would sure like to know. Thanks much. Mike. |
RE: Hobbico Lithium Volt Meter Discontinued
why not ask hobbico? Try over in the manufactures forum. If you mean the little cell tester for checking the cell voltage then they are available all over from various vendors. Try common sense rc.
