VPP - Variable Pitch Prop 4D flying Discuss VPP - Variable Pitch Prop 4D flying in this forum
Best servo for pitch??
Old 08-13-2005, 01:44 PM
exeter_acres
exeter_acres's Avatar
Default Best servo for pitch??
OK...still playing with my VPP setup....
I need a lighter/smaller battery...that I know
but I've heard that the HS-55 that I am using for the variable pitch servo doesn't have enough ooomph.
So...what would be the best servo for the pitch without adding extra weight???
Cheers
Exeter
Old 08-13-2005, 07:39 PM
mdavies31
Default RE: Best servo for pitch??
I'v got a BlueBird BMS-371 on mine, works great.
It's the same size and weight as a 55 but has 21 oz. of torque in .12 sec. compared to 15.27oz. in .17 sec. for the 55.
Here's one source for them: http://www.balsapr.com/catalog/Servo...ductId=T557857
ID:	309710   Click image for larger version
ID:	309711   Click image for larger version
ID:	309712   Click image for larger version
Old 08-17-2005, 11:43 AM
Baron Johnson
I've used both HS-55 and CS-4.4 servos for pitch on VPP's and both performed fine with proper mechanical advantage. Use an inboard hole on the servo arm and it should have the 'oomph' needed for either of the off-the-shelf VPP units available.
Baron
Old 08-25-2005, 10:52 AM
MalaysianFlyer
You could also try the GWS Naro F HP, 24oz at 0.10, and easier on the wallet!!!
Old 08-25-2005, 10:56 AM
exeter_acres
Thanks all...I'll take a look!
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
