VPP - Variable Pitch Prop 4D flying Discuss VPP - Variable Pitch Prop 4D flying in this forum
Manuel Nubel Mid mount VPP
Old 05-07-2006, 07:59 AM
growingupisoptional
Default Manuel Nubel Mid mount VPP
Have you guys seen the video of manual nubel and his mid mounted VPP?
His engine is mounted in the middle of the fuselage about the half way point of his wing.
With this he can touch the nose of the aircraft on the ground and roll it around on the floor with what appears to be absolutely no detremental effect to the aircraft.
It's about the best flying VPP I have seen.
Does anyone know what his setup is or where there is a webpage with more info.
The airframe must be EPP or something with the battering it takes with no damage.'
I would love then same setup.
Cheers J
Old 05-10-2006, 11:00 PM
spec36
spec36's Avatar
Default RE: Manuel Nubel Mid mount VPP
is the video on this site got a link
