Tail gear shaft replacement
Does anyone know how to remove the tail gear shaft from the boom on a Walkera UflyS? There is only (according to the parts breakdown drawing) the shaft, with a bearing on each end in the boom tube. I finally got one of the bearings off of the end of the shaft (by the main gear), had to cut it off), but no amount of tugging can pull the shaft from the tube. I need to replace this shaft before I can fly again HELP!!!
