Walkera V120D02 with 2801 radio
This is a shaft driven tail
Have any of you any experience with this Heli, would appreciate your input on this Heli as I am planning to purchase in the near future
It looks on the surface that the shaft holds very well and is fairly durable
Would appreciate your glowing comments if you have them
Bill Truax
Bill Truax
RE: Walkera V120D02 with 2801 radio
With any shaft/gear driven tail you have the problem of stripped gears. If you feel you are going to land hard , or crash, cut the throttle as soon as possible. Dont take off or land in the grass, as this will cause gears to strip. When you order it would be wise for you to also get spare main gears, tail gear sets, and drive shafts, as these are usually the replacement parts you will need most often. Good Luck with your purchase!!!
