EXI 450 PRO
NY
RE: EXI 450 PRO
so you want to know if the torque tube from a trex 450 will fit in a exi 450? im thinking it will as i have a 3xi and so far all the parts trex make fit perfect on the exi except main drive gear when you switch to trex parts i had to do the whole main gear tail gear and 1 way into it but the only differance was the 1 way bearing which trex ofcourse is longer lasting i hope this helps but im thinking you will have no problems at all
