Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
newbie question
Old 12-15-2011, 09:39 AM
chop1
Default newbie question
i have a contra heli from banna hobbies,it is a copie of the walkera v200 d1 or 180 d . i up graded the tail rotor to a dd motor and now it spins in tight circles out of control at take off . i can't get it to hover ,are any set tips to fix this ?
Old 12-15-2011, 10:19 AM
olefart
Default RE: newbie question
Check to see if you hooked the tail motor wires backwards. I did a conversion on mine, and put the wires to the rx backwards, making the motor spin backwards. This will cause the heli to spin. If you did a conversion that involves a shaft driven tail, check to see if both ends of the shaft are properly meshed to the mating gears. if not, make sure they are. GOODLUCK!
