Devo 7 set up /binding
I have the Walkera V120DO2S with Devo 7 TX and 2364 RX.The 3 swash-plate servo's appear to be turning the wrong way.As they go down, the swash plate goes up which gives the helicopter lift.If the servos go up the swash-plate goes down for inverted flight.I have just replaced the main shaft, swash-plate and had to remove the TX speed control tray to get access to the main gear.I really can't see how I disturbed the setting to cause this problem.I don't believe any amount of adjustment of the ball links will rectify this.I did notice a setting on the TX that said REV. I tried this but no change.
While searching the net I have seen a number of negative,and positive, statements regarding the Devo 7 and that the Devo 8 is a lot better.Also the fact tha[8D]t Walkera will not bind with any other make of receiver.
