Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
WALKERA 37
Old 07-20-2006, 09:11 AM
  #276
Heliwannabe
Default RE: WALKERA 37
Yes that was me, the picture is on page 10. Is it only my computer or is that picture super large? So far everything seems to be running ok, knock on wood. I do have a 30A ESC I bought for another motor as a backup but I'll just monitor things for now. When I used this battery with the stock motor it ran very hot and finally died. I disassembled it and the coils were charred and one brush was almost completly gone. Good thing I didn't damage the heli.
Jim
Old 07-21-2006, 12:59 AM
  #277
mcdaniel
mcdaniel's Avatar
Hi there
now I continue searching for brushless and esc for my Df#37
please any info about it. this is my first experience getting one.
http://cgi.ebay.com/RC-HELICOPTER-38...QQcmdZViewItem
eBay: RC HELICOPTER 3800kv Brushless Motor and 30AMP ESC (item 280009454971 end time Jul-29-06 14:11:07 PDT)
Old 07-21-2006, 06:46 AM
  #278
armycopter
armycopter's Avatar
The 60 guys are having good luck with this combo... it's a great price too.
http://www.ehirobo.com/shop/product_...oducts_id=4040
maybe you can pick one of these up instead?
Old 07-21-2006, 07:04 AM
  #279
W37 Cepeda
W37 Cepeda's Avatar
ORIGINAL: mcdaniel
Hi there
It looks nice, I recommend something with a little more pep. That's the reason you get brushless.
Go for the other one , it has 4200 RPM.. you should be asking yourself at what RPM level
is the max before you have to adjust your yaw. IT's not a matter of just poping it in,
some of us got lucky, but when so much power is applied, you will need to do some adjustments.
  #280
ellcheepo
Hi, guys I have found out about the metal rotor head and tail sections. It is the same as the 60 so if you want then then look at buying it from a good website for a 60 and it should be done. Mine is on it's way and I will up date you on it's fit and function.
Old 07-21-2006, 07:50 AM
  #281
soneebee
soneebee's Avatar
hello W37, the head that army posted for the DF37 seems to be very good.. I can see that it is a good copy of the Align SE head design.. is it already out in he market.. the one you posted is like a promo for the whole heli.. are they selling just the head part? I hve talke to eHirobo about the head and I am not sure when the head for the DF37 will come out.. but i think walkera will still make the head for this heli....
Old 07-21-2006, 08:21 AM
  #282
W37 Cepeda
W37 Cepeda's Avatar
METAL HEAD NEWS FOR DF37.
ACCORDING TO WALEKRA. THERE WILL NOT BE A METAL HEAD DESIGN FOR THE DF37.
THIS IS BAD NEWS.
IN ORDER TO GET METAL HEAD , YOU MUST PURCHASE A AFTER MARKET SYSTEM,
THAT MAY REQUIRE MODIFICATION.
SPECULATIONS REMAINS ON WHETHER THE DF60 HEAD COMBO WILL FIT,
THE ONLY ISSUE WITH THE DF60 SYSTEM IS THAT YOU HAVE TO ALSO
ACQUIRE THE FLYBAR FOR THAT HEAD, CAUSE THE ORIGINAL FLY BAR ON THE
DF37 is ABOVE THE MAIN ROTOR.
AND SECOND, THE MAIN SHAFT NEEDS TO BE VISUALLY AND MECANICLY
VERIFIED TO SEE IF IT FITS AND CONFORMS TO THE DF60 SYSTEM.
Here's a link to see the DF60 head system on ebay:
http://cgi.ebay.com/Aluminum-Alloy-M...QQcmdZViewItem
Old 07-21-2006, 08:30 AM
  #283
soneebee
soneebee's Avatar
the one that eHirobo sent me contains the flybar and the shaft already.. and the head is already assembled.. the only problem that i am seeing is the shaft.. the one that comes is designed for the main gear of the Df60.. I havent seen the actual DF37 gears so it will be the point of problem.. other parts might work
Old 07-21-2006, 08:49 AM
  #284
armycopter
armycopter's Avatar
Somebody is making a metal head for the 37. Here it is as an entire assembly....
http://cgi.ebay.com/RTF-ALL-Aluminum...QQcmdZViewItem
I emailed the vendor to see if I can get just the head, I'll let you know.
Soneebee didn't indicate that this head was exactly the same as his DF60 head, but seems to be more like the Align.
-Mark
Old 07-21-2006, 08:57 AM
  #285
soneebee
soneebee's Avatar
Mark this head that you posted really looks good an not like the one on the Df60.. it is really more of the AlignSE head.. it looks and has the same mixing.. so I guess this is like an align copy.. the one on the DF60 is really different.. even the mixing is different... If I were to choose between the Df60 head and that one.. the one on the Df37 seem to be better looking and the performance seems to be more of the aligns...
Old 07-21-2006, 12:09 PM
  #286
W37 Cepeda
W37 Cepeda's Avatar
You are wrong. Sorry to say it.. that will not work.
If you take a closer look, that is not the DF37 HEAD.
THE DF37 has the flybay over the mains.. That what you see there
is a TrEX450 and or simular DF60 Conversion.
Beleive me when I say... no one has a DF37 original head in metal.
But I give you credit.
Because it proves according to the pics, you
can adapt a DF60 metal head and flybar to the DF37.
ORIGINAL: armycopter
-Mark
Old 07-21-2006, 12:27 PM
  #287
armycopter
armycopter's Avatar
Let me rephrase... somebody is making a metal head that will fit the DF37.
Old 07-21-2006, 12:34 PM
  #288
W37 Cepeda
W37 Cepeda's Avatar
What remains to be seen and fact finding,
is to figure out, what is more beneficial.
The flyBAR. whether over the main rotors or under the main rotors.
I have to figure this one out. I'm sure there must be a difference.
All I can say is this, and not too defend the DF37, but I flew my friends
TRex450.. and it was not as stable at low hover as my plastic head 37 with the flybar over the mains rotors.
It seems that flybars over the main rotors achieve better balancing than under. could this be true?
This remains in my book as a real study issue.
Old 07-21-2006, 07:48 PM
  #289
Heliwannabe
What a nice looking deal. The price looks great considering the upgrades but ouch! on the shipping. I'll be keeping an eye on this as my plastic parts grind away.
Old 07-21-2006, 08:29 PM
  #290
balance_mind
W37
I think I agree with you that there will be a difference whether the flybar is below or above the main rotor.
I'm suspecting it gives better hover but maybe a dropped of performance in terms of reaction speed on turns and pitch control.
Well guess we need to further study on this.
Army
that combo looks great. Finally a CNC head for the #37. But like what W37 says, it's not totally a true head for #37. I guess the vendor must have modified it to fit.
But worth keeping track on this combo. Do post us the results on your queries to the vendor.
Old 07-21-2006, 11:41 PM
  #291
mcdaniel
mcdaniel's Avatar
hi there
well finally I crash my heli ,I hope you can help me,Everything is good only problems with main rotor blades.
so now I have two main blades in my hand.
so I need :
rotor main blades.
the main blade holder are good no damaged but a metal shaft for conected two main holder is broken looks like principal axis(I not sure), it seen that also come with bearings that are missed also. the two ball linkage set that conected from two main holder are ok. so it seen that with rotor blade, bearings and this metal shaft I could fly again, so in the df#37 parts I dont see this shaft ? which part number will be ?or maybe it will come include in blade holder item.? the bearings is in bearing set part?
thanks I need that you tell me exact items that I already need, to place an order.
ps:Good price for brushless and Esc on HIrobo ,I will get this combo.
thanks Armycopter
Old 07-22-2006, 12:55 AM
  #292
soneebee
soneebee's Avatar
ORIGINAL: W37 Cepeda
I have asked you guys this question a couple of weeks ago on the thread.. and I think no one has been thinking what is the real difference.. The only thing that i can see theoretically is that when the flybar is at the farthest point of the CofG the response time will be faster cause the effect on the gyroscopic forces is greater than when moved it closer to the CofG but this is theoretical.. since i have used both head on the same heli I really cannot compare.. the CNC head on the DF60 is very responsive eventhought the flybar is at the middle.. the only thing that i can see advantageous with the blades farthest is it can lessen the possibility of boom strikes.. when i got the original head on teh DF60 i had 2 boom strikes just because of a bad drop or landing of a foot or so.. but i did it with this head well it did not hit the boom yet..
Old 07-22-2006, 07:46 AM
  #293
armycopter
armycopter's Avatar
For all of you that crash and have the MAIN ROTOR SHAFT bent "HM-37-Z-09 "
"the shaft the holds the blade holders"
I found a ALIGN replacement.
Mfr:ALN
Part #: ALNHS1003
Price: $6.29 ( in a Florida hobby store )
AND YOU GET 4 in the BAG. just around 6.50!!!!!! SUPER!
Visually and mecanicly installed by me. Go ahead and order AWAY!
Normally one of these for the DF 37 is about 5.00 bucks. JUST FOR ONE UNIT! "[email protected]@@@S"[:@]
mcdaniel
Cepeda found that the Align feathering shafts fit the DF37 and they are less expensive. (plus you get 4 in a bag). Also, if you look on page 8, he found out that you can use the align blade holders, bearings, etc and they are of higher quality (metal blade holders).
If you simply want walkera parts, I think this is what you'll need... (see pictures)
The shaft is HM-037-Z-09
Old 07-22-2006, 08:29 AM
  #294
soneebee
soneebee's Avatar
mark.. are the head assembly of the DF60 and the Df37 the same.. i think they are... I have tried the feathering shaft by aling this are better than the ones walkera uses. it is harder and mot robust than the walkera.. and it comes in pack of 4.. but havent tried the blade grips yet.. but i think they are also interchangeable
Old 07-22-2006, 10:04 AM
  #295
armycopter
armycopter's Avatar
soneebee,
cepeda tried them and they work for the 37. I'm not sure on the 60. On another note, you inspired me to go try nose in hovering this morning. I went through a battery pack with more success than failure so I'm pretty happy. I need to get the nose in thing down if I want to continue this hobby. Hopefully I can get good at it. After that I'll try some fast forward flight and figure 8's. I can do slow forward flight from side to side and good "tail-in" hovering but that's about it....
Old 07-22-2006, 10:33 AM
  #296
soneebee
soneebee's Avatar
that good mark since you can do almost all that is written on the book.. after nose in then you will going inverted... that will be something....
Old 07-22-2006, 01:41 PM
  #297
mcdaniel
mcdaniel's Avatar
Ok the parts are ordered , also the brushless motor and ESc from E-hirobo
we keep in touch when everything get to me ,
thanks again ARMYCOPTER
Old 07-22-2006, 03:23 PM
  #298
W37 Cepeda
W37 Cepeda's Avatar
ANOTHER ALIGN PART REPLACEMENT
IF you landi ng skid is broken on your DF37
it can be replaced with ALIGN PART# HS1098t (yellow)
The landing kit set come in different colors too.
They fit perfectly.
Old 07-22-2006, 05:57 PM
  #299
armycopter
armycopter's Avatar
Thanks Cepeda, good to know!
Old 07-22-2006, 06:12 PM
  #300
mcdaniel
mcdaniel's Avatar
Hey W37 CEPEDA
THANKS FOR THIS INFO WILL SAVE US $$$$$, BUT COULD YOU TELL US IN WHICH STORE IS AVAILABLE THOSE REPLACEMENT ALIGN PART,
MAYBE Ebay or your favorite store???
thanks bro.
