Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
WALKERA 37
Old 11-19-2006, 10:18 AM
  #826
Default RE: WALKERA 37
Here are some pics of some of my rc collection. Hope it works
Tom
ID:	562989   Click image for larger version
ID:	562990   Click image for larger version
ID:	562991   Click image for larger version
Old 11-19-2006, 01:59 PM
  #827
Thanks tommie! that is some collection you have!
I got the tail as part of an upgrade from ehirobo that came with the 60 metal head, elf hobby motor and esc. I had the 60 head installed but it wasn't quite right. So the head is now a conglomerate of walkera and sonix parts due to lots off crashes. It's no trex head but definately more durable now.
Old 11-20-2006, 02:09 PM
  #828
hey guys,
i tried flying my heli again and tail doesnt spin anymore but i encountered a different problem.......
when the heli try to lift off, the heli try to tip itself to the right when you look at it in the front....
also does the paddles need to be angled when they get screw in?
how about the main blades? should they be o degree after it initilize when no throttle is applied??
thanks
ed
Old 11-20-2006, 02:21 PM
  #829
W37 Cepeda's Avatar
The paddes are required to be leveled after you screw them in.
The only purpose the paddles have are to make the heli controllable by
keeping a proper balance, by using the weights you see attached,
Professional flyers remove these weights to enhance controllability and responsiveness
which are needed to do 3d tricks.
Concerning the blades angle, (pitch) that depends on your personal settings.
Some of us have lzero angle for starters. let me advice, this is a real bad thing.
Cause if you go outside and the more learn to fly, you will see that when
you want to bring the heli down, it will not come down eaisly and you will
loose control.. You bring the throttle down, and you get is the BALLON EFFECT,
its all over the place. Thats why is good to have a bit of negative pitch, so that
im a windy condition that can happen at anytime, you can bring it down under control.
W37
ORIGINAL: streetforcegp2
hey guys,
thanks
ed
Old 11-20-2006, 02:44 PM
  #830
ORIGINAL: W37 Cepeda
W37
hey guys,
thanks
ed
do you know whats causing the heli to tip to the right??? cause instead of lifting off straight up, the heli lift to its right???
Old 11-20-2006, 02:48 PM
  #831
W37 Cepeda's Avatar
Apply power to the remote. Apply power to the heli. Do not throttle up.
Always turn on the remote 1st.
Make all your trims on your remote centered.
Visually inspect the swashplate. It must be exactly leveled in relation to
the ground and body of the heli. Look at the swashplate with the nose
of the heli facing you.. ( becareful, make sure you dont apply throttle!)
you will see if it's more to the left or the right, or back or forth...
Once you see the problem, you can fix it my adjusting the linkages to go from
the servos to the swashplate.
Then after you do the mecanical adjustment, and can't no more, then you go
to your trim on the remote control. Keep doing this until you feel
confident with the results. Trail and error.
W37
W37
hey guys,
thanks
ed
Old 11-20-2006, 06:06 PM
  #832
arghhhhh...im soo frustrated right now heli wont fly......
im back to the spinning problem.........now the heli turn clockwise instead of ccw!!!
i think the stock motor and battery sux cause seems like the heli only lifts off couple of inches off the ground and just keep spinning.......
i think im setting the rudder wrong....i turn dipswitch 12 and start adjusting v1 and v2 but i just cant get it?
how should i setup the v1 and v2 if dipswitch 12 is on?????
Old 11-20-2006, 08:10 PM
  #833
Quite some time I have not used the Walkera Tx.
If I remembered correctly to remove rudder mixing,
CCW set all the way for V1 and CW all the way for V2 which means +100%. Rudder mixing and AVCS cannot run together.
For your tilting problem, other than your swashplate, make sure your CG is not way too off.
If it just drift to the left (viewed tail-in), it's perfertly normal.
To trim your heli, bring it to a hover at eye level and at the same time you can also see if the blades tracks ok.
Old 11-21-2006, 10:08 AM
  #834
W37 Cepeda's Avatar
OK.
First thing: Make sure your blade tracking is correct.
Lets forget about AVCS mode for know. Lets get the heli at least to fly level.
Switch the Gyro to Normal mode. ( with the power off), on the gyro, also move the
POT to 40-50%. On the remote make sure you have DIP#7 on.
This is assuming you have done a proper mecanical rudder adjustment, if not
let me know.. I can tell you how to do it, but basicly everything has to be
centered, the servo bellcrank, and also the rudder position at the rudder itself.
all nice and centered when you apply power with the remote on and the rudder trim
centered.
With the remote power off, goto dip switch # 12 , and move that to the on position.
Also, move V2 and V1 to ZERO, thats dead center.
The knob on your right, I think its V1, is the rudder mix adjustment when you have DIP #12 on,
and the knob on your left is the gyro sensitivity adjustment, also when DIP #12 is on.
Apply power to the REMOTE. Notice the different logo color "WALKERA" this indicated its in programming mode for #12 DIP.
Apply power to your heli. Make sure its facing the tail to you.
Throttle up and try to hover. if the tail wags left to right, LOWER the gyro sensitivity, V2.
When you apply power and it tends to rotate more as power is applied, that means your rudder mixing is low.
The way it works, the more throttle up , the more it should mix. (meaning it moves the rudder more to compensate).
So adjust accordingly (v1)
try again. If this does not work, then you have another issue, it could be your rudder is reversed. etc. etc.
I will think of some more reasons on why this can happen. There is a rudder REV swtich on the GYro, make sure
you have it set correctly.. ..lRepeat.
Once you find the proper setting, DONT POWER OFF THE REMOTE. LEAVE THE POTS ON THE POSITION THAT WORKS. THEN CAReFULLY
SWITCH DIP#12 to OFF, THEN POWER OFF. THis will store that POT setting into the memory.
GOod luck
W37
Old 11-21-2006, 01:18 PM
  #835
how do i check blade tracking???? by looking at the spinning blades to see it the red and blue tape are even????also when i power up seems like blade tend to spin smoothly......and what is the maximum pitch can i set the main blades?????
hey cepeda,
i was about to go step y step on ur instruction but my tail assembly is a bit mess up cause i tried flying it and it hit my cabinet......
thanks
ed
Old 11-21-2006, 02:05 PM
  #836
W37 Cepeda's Avatar
In your manual its called main rotor blade adjustment. Just follow the instructions.
Also.. if you give up trying to fix it... let me know.. I can help you. Right know i have 3 copters im working
on for people that sent it to me, cause all the local places are booked.
Email me, we can talk.
W37 Cepeda
hey cepeda,
thanks
ed
Old 11-21-2006, 06:11 PM
  #837
im not giving up but sadly i broke the tail holder and bended the shaft so i have to order a new set......
thanks for the help
ed
Old 11-21-2006, 07:24 PM
  #838
anyone have an extra tail blade holder????im talking about the stock one...
thanks
ed
Old 11-21-2006, 10:18 PM
  #839
W37 Cepeda's Avatar
Yeah. I have some.
MSG me..
thanks
ed
Old 11-21-2006, 11:24 PM
  #840
Yeah. I have some.
MSG me..
thanks
ed
what was your email again i cant find it on my list sorry
thanks
ed
Old 11-21-2006, 11:49 PM
  #841
cepeda,
i sent you emails.......
thanks
ed
Old 11-22-2006, 01:01 AM
  #842
what should be the setting for the dipswitches if using normal mode on gyro?
how about when using avcs mode what should be the setting of the dipswitches?
thanks
ed
Old 11-22-2006, 01:33 AM
  #843
does any use the elf hobby brushless motor w/30a esc?
heres a link
http://www.ehirobo.com/shop/product_...oducts_id=4040
and will this li-po work w/both of the motor and esc?
battery link
http://www.ehirobo.com/shop/product_...oducts_id=4015
thanks
ed
Old 11-22-2006, 08:42 AM
  #844
W37 Cepeda's Avatar
If yo set the Gyro in normal mode,
you must set the rudder mix DIP #7on the remote to ON
If you use AVCS, rudder mix should be set to off position.
w 37
thanks
ed
Old 11-22-2006, 12:34 PM
  #845
alright thanks
Old 11-25-2006, 01:07 AM
  #846
does anyone know if this tail assembly fits the 37????
http://www.ehirobo.com/shop/product_...oducts_id=4776
Old 11-25-2006, 01:10 AM
  #847
hey guys,
hope ya'll have a nice thanksgiving.......
does anyone know if they make cnc upgrades for the 37????
thanks
ed
Old 11-25-2006, 11:44 PM
  #848
mcdaniel's Avatar
HI there
Well , for those who follow this forum everyday , few weeks ago we have been discuss about suddenly lose of power (rpm) for instance during flying session, since 12c batt should works well ,I order a new ELF HOBBY 30 Esc (last version) and replaced the old ver Elf hobby 30 ESC . let me tell you people, that after 10 batt pack test done , it never do it again , finally, My ultimate flying machine is flying perfect ,very stable and 100% FREE GLITCH .
Hope it help for those user of ELF combos in their machine.
Thanks.
ID:	566727   Click image for larger version
Old 11-25-2006, 11:48 PM
  #849
where did you buy the elf hobby brushless system w/esc???
thanks
ed
ORIGINAL: mcdaniel
HI there
Thanks.
Old 11-26-2006, 02:25 AM
  #850
is anyone using cnc tail assembly for their df37?????? if so where did you buy it??
thanks
ed
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
