WALKERA 37
#1351
MO
Ha, I had a Sabre FP, Biggest POS I ever saw. Owned it seven months and flew for about seven minutes total! Spent more money on it than a Trex and almost let it drive me out of the hobby.
Until I took a chance and got a 36 I thought that I wouldn't be able to fly a Heli at all! Big difference! Actually flys for more that a few seconds without breaking down.
Hats off to the people that can fly a DF4 or one of the other versions that are being sold with different paint schemes.
And yes I am bitter over the experiance.
#1352
MO
Hello all,
Sorry about that last rant but fixed pitch tail motor Helis are a sore subject with me.
Anyway I was correct in that I was creating a monster 37. This thing is unreal! Time to dial in the expo! This is going to be fun when I finnally get to fly it out in the open.
#1354
CT
Here's my problem, I'm a novice with a 37. Havn't really had a successful hover but a few crashes. Had a bad pitch servo so I bought a new pack of them and took care of that. Now it wants to spin one way or another and will finally correct with full rudder but start in the opposite direction. No middle ground. Driving me nuts. Can some one give me the order of plugs on the receiver as well. Perhaps something there is missed up. I've read this forum and find it very informative but I guess I'm behind the learing curve still.
Thanks in advance.
Captgww
Thanks in advance.
Captgww
#1355
MO
Sorry guys, I thought that this thread had died.
Did you try reversing your gyro? It sounds like that might be the problem.
If you have control of the Helis direction (forward-back, left-right) then those servos are hooked up correctly. Channel three is the esc, four is always rudder, five is the gear channel, six is the pitch, and seven is gyro adjust if you have that feature.
Check that your tail blades are rotating in the correct direction and that they are installed correctly. It is hard to belive how often that Walkera screws that up!
I'll check back to see if you have more questions.
Huey
Huey
#1356
FL
I'm back too.
And good news... have tons of walkera parts!
going to open a on small online store.
W 37
W 37
ORIGINAL: babyhuey
Huey
Huey
#1357
MO
Cool Cepeda,
It's amazing how the parts start adding up. I already have built an entire RTF 36 from spare parts and now I just figured out that I have enough extra parts to almost build a Raptor G2 ARF.
Just need a Trex xl belt and an esc to finish it.
Post a link to your store when you get it ready.
Looking forward to it.
Huey
Huey
#1359
FL
OK.. Which is the best battery?
This is the question of the new year. Everyone has many opinions.
No one has a definte answer, cause many batteries are used in different ways.
But, if you are a casual flyer, maybe doing some 3D, barrel rolls, 360 loops, not pushing it at all
I recommend FLIGHT POWER EVO 2500Mah 11.1V Lipo. Along with the ULtra Balancer (blinky clone but better) if your not using a balance charger.
This battery does not puff up and has an excellent warrantee. EVEN WITH CRASHES! Don't waste money on anything else. And remember to
use caution when handling LIPOS. Do not over discharge and do not over charge.
Flight time on the Walkera DF60 = 18 minutes. DF37=17 minutes. Df36=16.5 minutes.. All normall fly mode, Idle 0.
#1360
FL
OK.. Should I build a hybrid?
Absolutly. Hybrids offers more expansion than conventionals. Many more options too without hitting the pocket.
Here is example of my 450 hybrid. This unit flies better than an original 450XL. It's lighter and the body is stronger.
#1361
MO
You are so right about the 600, My dream Heli. I figured out that if I sell every thing I own in this hobby I could get one but I'm not ready yet.
On your hybrid, What did you use to make it? It looks awsome!
Huey
Huey
#1363
FL
MO
Is one of them complete? Then it's a good deal. By the way I have tried both and prefer the plastic 37 head as the alloy one is a completely different design and is poorly made.
#1373
MO
That's to bad as it seems like a good deal. Speaking of good deals there is a 50 shuttle RTF on ebay for $400 that is complete with Futaba 8 channel radio system and motor and gy401 gyro/digital servos!
Man I wish That I had the cash!
#1374
W37,
Need your help mate. I have not been flying my W60 (Alum Head - I understand it has the same setting as the W37) for about 3 months. Took it out the other day and have noticed
that the front servo tends to travel farther that the cyclic servos when I hit collective. I have switched servos, changed the receiver but to no avail.
Because of the imbalance (front servo travelling farther that the other two servos), the heli tends to move forward even though all
i want it to do is hover. My question is, has anyone ever encountered this before? Could it be that my tx is busted? Or is there something that i can still do to fix the problem.
Any help will be much appreciated.
Cheers
Ausaero
Cheers
Ausaero
#1375
MO
You might be able to move the front servo link up the arm, closer to the servo to shorten it's throw. Assuming that they all start at the same level in the first place.
