Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
Well just crashed my 36 - help
Old 06-08-2006, 01:37 PM
Default Well just crashed my 36 - help
Well just crashed.... pilot error as usual. So I have bent my Main Blade Transverse Shaft. I have striped it down but I cant see how to remove it from the T bar??
Any ideas? Cheers! Manc.
Old 06-08-2006, 01:52 PM
sportygreg's Avatar
Default RE: Well just crashed my 36 - help
You should be able to pull or drive it out-I don't see any pins or screws on mine that hold it.
Old 06-08-2006, 02:09 PM
Does not want to budge []
Old 06-08-2006, 02:23 PM
ORIGINAL: manc_heli
It is the spindle, remove the main blade, unscrew the 2 screws on top of the blade grip, the upper and lower grip will pop open and you will see an O ring, a plastic spacer, 2 bearings and a lock nut. You may also check the main shaft which bents easily.
Old 06-08-2006, 02:40 PM
Yep was being daft, sorted now thanks! Put a nice 5 deg bend in it!
Main shaft seems ok.
Old 06-08-2006, 10:03 PM
sportygreg's Avatar
I thought he already had blade grips etc stripped off.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
