430l keep cutting off
hey
i recent got the align 430L + align 25a esc and after a long while soldering the damn thing together, i finaly got it working
it is really powerful and i love how the air rushes in and out when it runs.
however the motor keeps cutting off once i raise the throttle stick.
this doesnt happen when the battery is full charged but as it weakens, the throttle cuts off at certain points.
and the points go lower as battery dies.
what do i do to make it so this doesnt happen?
thanks
thanks
FL
RE: 430l keep cutting off
The ESC has a cutoff set at a certain voltage to protect the battery.For 3s Lipo it is usually 3V/cell-you may be using too big a pinion gear and draining battery too fast.The cutoff voltage can be programmed using throttle stick but you need the instructions for Align ESC.
