Go Back  RCU Forums > RC Helicopters > Electric RC Helis > Walkera Helis - Dragonfly, etc..
 Which Walkera Dragonfly is the best? >
Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
View Poll Results: A poll
22D ($225)
0
0%
22E ($149)
16.00%
35 ($270)
0
0%
36 ($219)
12.00%
36B ($289)
4.00%
37 ($239)
4.00%
60 ($189)
16.00%
60B ($299)
28.00%
60C ($299)
0
0%
68B ($369)
20.00%
Voters: 25. You may not vote on this poll
Old 12-15-2006, 08:48 AM
Default Which Walkera Dragonfly is the best?
Compare everything except battery and motor!
Prices are approx and come from ehirobo.com including shipping. Please vote and write your comments about it!
Old 12-15-2006, 09:32 AM
helifan06's Avatar
Default RE: Which Walkera Dragonfly is the best?
The price is good, I got a Raptor G2 from exceedrc (aka Walkera 36), with Brush Motor and NiMh battery. I don't know what is the difference with 60B, only price I guess. I couldn't make it take off more than 2 inch, now the motor doesn't spin. I order new batteries and new Motor too. Right now, I have 2 weeks without been able fly.
But my recomendation is to go one step further and spend a bit more money to get it with Brushless and Lipo Battery, I suggest Walkera 36 Pro, version. It is worth it, with spare parts and shipping it will cost me the same at the end.
helifan06
Old 12-15-2006, 10:18 AM
Yes. I really agree with you. Going for original engine seems like a suicide. Better to upgrade to a better one instantly. I've found some differences between 36B and 60B, question is what is best?
Comparision: 36B - 60B
- Main Rotor Diameter: 622 - 620 mm
- Tail Rotor Diameter: 135 - 145 mm
- Overall Length: 600 - 600 mm
- All-up Weight: 600~635 - 570~620g
- Servo 36B: weight 9.1g / speed 0.12sec/60°/ torque 1.1kg/cm / dimension 22.5X11.8X27mm
- Servo 60B: weight 8.5g / speed 0.11sec/60°/ torque 0.9kg/cm / dimension 22.5X11.5X24mm
- And almost forgot Pricedifference: $10
That's the only difference I've seen. Is it better to have a larger Main Rotor diameter or a tail rotor diameter? I've heard some people had the tailrotor that hit the ground...
And what difference does it make with a 9.1g or 8.5g servo? Seems that 60B is lighter in general also...
Old 12-18-2006, 04:48 PM
cyclicoverload's Avatar
I went with the 60, newer style frame and a better main rotor head(stock), i have two of them and left one alone and fixed up the other, thay both have a place. I really like flying my stock 60,for the money it cant be beat!
Old 02-15-2010, 09:49 PM
I owned a 4 channel ExceedRC Falcon 40 with NiMH batteries.
After the 40 or 50th flight, it too would only lift about 2 to 6" off the ground.
At first I thought it was the battery, but then it did it with the second battery, too.
I applied a very small amount of lubrication (WD40 or Break Free) to the bearingat the top of the rotorshaft and then turned the helicopter upside down and applied a little to the bottom of the shaft.
That helicopter then flew like it was brand new.
Try it, but be frugal.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
