Walkera Helis - Dragonfly, etc.. Discuss Walkera Dragonfly Helis and any Walkera products in this forum
CB180D issues
Old 07-03-2010, 06:44 AM
ksm1969
Default CB180D issues
Hello. I took ouest my RX2423 out of my CB180D with the main motor and tail motor. I walked around the yard trying to find a cure for the range issue. I came up with zip. I then soldered a longer wire and nada. No matter what i did i cant cure the range issues.. I was wondering is there another receiver that will work?? HMMM
Old 07-04-2010, 09:27 PM
ehirobo ehirobo
Default RE: CB180D issues
Do not change the length of the antenna for the rx. As it is design accordingly soldering a longer antenna may shorten the range.... Solder the original one back on, make sure it is pointing away from battery, motor, esc and it is not touching any metal or carbon fiber parts.
