simulator software problems
Hi has anybody tries to use the dragonfly walkera 36 transmitter with a serial cable ? i am at the minute using the walkera tx which has the walkera name in the shape of a heli i am trying (have been since yesterday) to get the cable software and tx to work together but i keep getting the same problem
i have installed ppjoy and setup a virtual joystick 2 on com 2 (ive tried other comports also) i am running ppjoyserial stream to virtual joystick i am using the zhen option successfully opened port waiting for stream init stays there forever can anyone help i have tried everything i can think about and i suppose it could be the cable any ideas the cable has 4 wires on pins 2 4 5 and 7 please help as im about to go insane |
RE: simulator software problems
scousethief,
Com2 does not work for ppjoy, you need to use com1. If you switch in ppjoy to com1 and do not get at signal, then something is using it already.. (Palm pilot or PPC will use com1..). ORIGINAL: scousethief Hi has anybody tries to use the dragonfly walkera 36 transmitter with a serial cable ? i am at the minute using the walkera tx which has the walkera name in the shape of a heli i am trying (have been since yesterday) to get the cable software and tx to work together but i keep getting the same problem i have installed ppjoy and setup a virtual joystick 2 on com 2 (ive tried other comports also) i am running ppjoyserial stream to virtual joystick i am using the zhen option successfully opened port waiting for stream init stays there forever can anyone help i have tried everything i can think about and i suppose it could be the cable any ideas the cable has 4 wires on pins 2 4 5 and 7 please help as im about to go insane |
#36 transmitter does NOT implement Zhen Hua protocol!!!
http://milehighwings.com/faq.htm#10 If your interface cable has just 4 straight wires with no microchip inside the serial connector's hood, there's no way this "interface" will work with your transmitter! Thia has been discussed many times, try searching this forum. Boris |
I have to agree the standard com cable for the Walkera 6 Ch transmitters does not work.
We have modified the cable to a parallel version and it works great.. In the middle of finishing a batch of 200 cables |
http://infomirror.blogspot.com/2006/...tor-cable.html
I have written up a quick guide to getting it working. I hope it helps! |
Do you know if this works with the 22E transmitter? It is also 6 channel but are they the same?
Thanks |
Hi cmarv8
ORIGINAL: cmavr8 Do you know if this works with the 22E transmitter? It is also 6 channel but are they the same? Thanks Circuits and pinouts are elsewhere on this forum. I posted a setup for the 22E recently after I set one up for a friend. David |
Thanks, I will look for it in a few days.
Here is an howto of the cable I made for my 22e, a 6ch tx. Might be the same for the #36?
[link=http://ehsia.com/49]http://ehsia.com/49[/link] http://ehsia.com/rc/walkera-22e-para...el-cable06.jpg |
Perfect! Thanks!
I also seem to have problems with FMS generally. It doesn't run smoothly. Sometimes it responds perfectly to my keyboard commands, while others it needs up to 4 seconds to aply the requested action! My pc is quite good for fms's graphics. Athlon xp 2800+, 1gb ram, ddr400, ATI 9600xt 128mb... It should be going perfectly. I tested the two latest versions. Please note I am using Winxp pro sp2. Thanks again for the instructions. They will work perfectly for my 22e controller. (waiting for the postman...). I'll keep you posted! |
Hi all: I'm a newbie electric RC guy, and I'd like to use FMS and a usb interface I bought from SIMBLASTER.com. as an easy way to enter the simulator world. The FMS works fine with a Microsoft joystick, but I cannot get Windows XP Media Edition to recognize the USB interface so that I can use it with a Futaba T6XA-s transmitter. Has anyone had this problem? The company has already replaced my first "non-functioning" unit, but I'm becoming convinced that the real problem is a compatability issue between the USB interface and Windows itself. Any feedback would be appreciated. By the way, I've seen G3, Reflex, and AeroFly. Can I get a recommendation for the best "hi-end" sim BEFORE in invest? THANK YOU! RON W
| All times are GMT -8. The time now is 12:33 PM. |
