#36 brushless?
i have a 36 going to arrive any day now. i have read that the brushed motor is pretty much garbage. unfortunatly i found this out after i orderd it
what is the best brushless motor and esc that you can put on this bird to get the best results? i also orderd 2 lipoly batterys with it and need to know what a good charger for them would be and where to get it thanks |
RE: #36 brushless?
Align seems to be the motor of choice. The 420LF and Align 25A ESC are serving my well so far.
Some people are trying the 430 now on their #36's too. I wouldn't recomend the Walkera brushless motor or ESC, from what I've heard the motor runs VERY hot and the ESC quality is questionable. Not worth the risk just to save a couple dollars. Can't help you much with a charger as I don't know whats available in the US. A lot of Aussies(myself included) like the 'Swallow advance' charger. It handles Li-PO's Ni-Cad's and just about everything else. |
RE: #36 brushless?
I'm not worth much for chargers (as I don't have any really good one... anyways ;) ) BUT for motors, Okisub's right, the prefered motor for the 36 is the 420LF with the align 35A ESC, and let me tell you WORKS GREAT!
RE: #36 brushless?
Ditto :D
RE: #36 brushless?
WELL WHAT ABOUT THE 3550KV WITH 35 ESC AND 13 T PINION OR 11TPINION WICH ONE WILL HAVE LOWER CONSUPTION??? OR WHAT IS THE BEST ??:eek:
RE: #36 brushless?
well if i buy the 420lf will i need a new pinion then?
| All times are GMT -8. The time now is 11:11 AM. |
