Help, please
hi ive been flying helis for about 8 months , and i recently got a walkera 60 , with a metal upgraded tail , could you tell me how , i stopp the tail from spiining anti clockwise .
if you think you no how i could fix it , please contact me on msn for a quickesr responce [email protected] thanks alot |
RE: Help, please
Hey, do you think you could expand on that problem, what exactly is spinning off? the tail rotor blades? the tail rotor housing?
RE: Help, please
hi yes , the tail is turning off too the right ,, or when you increase tnhe power it spins really fast [&o][&o] nuthing is actually coming off the heli just the tail is spinning madly anti clockwise
thanks , please help [&o][&o] |
RE: Help, please
heh, I think the tail belt was installed incorrectly, check something for me
turn the main blades by hand (non powered) is the tail blowing out to the left or right (tail pointing towards you)? Also, is the tail spinning where the sharp part of the blade is the leading edge or the blunt part? Which way is the tail turning? (clockwise or counter) Also before you adjust anything, try one more thing, flip the reverse switch on the gyro. |
RE: Help, please
Hi , I have taken photos :D please take a look it shows which direction the airflow is going ,, allso the blunt edege leads
http://i17.photobucket.com/albums/b6...PICT6682-1.jpg Please help [:o] i have tryed the reverse switch with no change to how it works , thanks alot |
RE: Help, please
Hah, EASY fix, you've got the air blowing the wrong way. flip the tail blades around, then, take the belt and with a 180 degree twist (I don't remember which direction, try one way, if no difference try the other way) and that'll solve your problem!
RE: Help, please
hey im having problems getting the tail section off the walkera 60 could you please tell me how i would remove it , the shaft doesnt seem to want to come out of the gear
thanks |
RE: Help, please
ive got it off :D:D:D:D
| All times are GMT -8. The time now is 07:33 AM. |
