Walkera36 no control
Hi, I hovered the walkera36 15min with brushless motor, ESC tower pro 30A and lipo 11.1v-1800mAH 10c all ok, I changed lipo a 11.1v-2200aAH 10c then problem, more power was used to get off ground and when it did sprang up to 1 foot where I hovered it, 2min into hover heli pointed skywards and started going backwards, hit ground and lucky training gear was on did no damage, the whole time I pitched forward and cut throttle but nothind happened, heli stopped on its own, this happened the following day to. Glad I wasnt ant higher than 1 foot from ground. Anyone HELP
RE: Walkera36 no control
Hi - I have a similar problem - see below - Did you get an answer or find a solution to your problem?
PLEASE HELP ME!!! I have a Walkera 5#4. Whenever I fly the heli does funny things. When I am just 2m above the ground the heli will just suddenly full throttle and I have no control over it for a few seconds. Sheeww... recovered that one. Then again about 1m from the ground it just suddenly decides to go left and spin out of control. Crashed into wall ;( It also sometimes seems very unstable when trying to hover (it swings). I have checked the batteries in the transmitter - they all seem fine, the heli is about 3 weeks old, and been charged about 10 times. Has a LiPo battery in heli. Help me - How do I fix this problem? Thanking you in advance for your help. Thank you. naz |
