War Room Discuss historical, battles, battle grounds, events, combat strategies and more right here!
M-51 Tam-Mato IDF Sherman
Old 12-14-2010, 04:57 PM
pattoncommander
pattoncommander's Avatar
Default M-51 Tam-Mato IDF Sherman
After a lot of customizing and fitting issues, my early M-51 is about done. Had to rebuild the Mato T-23 turret with the 105mm, rear overhang etc, cut the bottom to lower the turret height, replaced the split hatch with the standard TC model, rebuilt the Mato A1 deck for the early (mid 60s) Cummins Diesel and vents, added extended fenders and all the stowage boxes and the huge stowage bin on the rear. The Mato upper hull was a decent fit on the older Tamiya lower hull, but getting it to stay in place was tricky. I used the side clips from the Tamiya upper hull and had to add about 3 mms to give it a tight fit and added two retaining screws at the rear above the tracks. Waiting now for stowage items and a set of German Jerry cans to complete the build. Turret marking Alef (א) and cal 50 have been added, but I eed a 60mm mortar and drill out the TC episcopes and glass in. Next is electronics to get it rolling. My IDF company now includes 2 M-51s, 2 M-50s, M-1 Super Sherman and an M-3.
This is the model Tamiya should have put out.
BEEN HAVING A REAL HASSLE UPLOADING PHOTOS...FOR SOME REASON THEY ARE ALL SUPER LARGE AND "CLICK TO ENLARGE" WORKS IN REVERSE.?????? Will try again.
Old 12-14-2010, 05:17 PM
pattoncommander
Default RE: M-51 Tam-Mato IDF Sherman
Will try uploading a couple photos..
ID:	1534258   Click image for larger version
ID:	1534259   Click image for larger version
Old 12-14-2010, 05:24 PM
pattoncommander
Webmaster....What is wrong with uploading photos? Why is the first OK and the rest super huge? My uploading of photos has not changed...same camera, same computer, same method. what gives?????
Old 12-14-2010, 09:47 PM
YHR
YHR's Avatar
I typed a complaint to the moderators over the picture hosting glitch. The last time I tried the search engine it was hooped as well. Two unfortunate developments.
Old 12-15-2010, 05:17 AM
pattoncommander
strange....I have no problem emailing photos, but on this site..[:'(]
Old 12-16-2010, 06:21 AM
YHR
YHR's Avatar
You have to now post one picture at a time, otherwise you get supersized.
