Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Tanks > War Room
Reload this Page >
opening Pershing hull hatches
War Room Discuss historical, battles, battle grounds, events, combat strategies and more right here!
Old 07-15-2012, 08:34 PM
pattoncommander
pattoncommander's Avatar
Default opening Pershing hull hatches
Someone posted a thread long ago on opening molded Pershing hull hatches using a thread. Would like to find info on this method.
Old 07-16-2012, 07:19 AM
mustclime
mustclime's Avatar
Default RE: opening Pershing hull hatches
I have always just done it with a micro drill and a knife...
Old 07-16-2012, 12:37 PM
pattoncommander
thanks, might give it a shot, but was interested in the thread deal.
Old 07-17-2012, 05:18 AM
mustclime
mustclime's Avatar
For the tread trick, you need the to clamp the plasic hull so you can draw the twine/thread without loading/cracking the hull....I just do not have the a clamping system todo this.The main trick with the drill trick is to use a very small bit angled inward so you will have an tappered seam for the hatch to fit into.....you want the rough edges as you thensmear green putty on these rough edges to fill in the holes that you justdrilled..then you sand them.This results in almost no seam or loss of plasticif you do it right. The thread trick results in a loss of plastic the thickness of the thread.
Old 07-17-2012, 04:01 PM
pattoncommander
Thanks Scott.
I'll probably do the drill thing..I have some really thin ones. The hatch will not be closing though. The driver's hatch should be open with a driver, as the T-23 was a research tank and a tank in testing is rarely driven buttoned up. I have the rear redone with the rounded features and tow cable brackets and Nick's aluminum 76mm gun in, and it's starting to look more historically correct.
Now I'll start on the hatch and put in a driver.
Bill
Old 07-18-2012, 11:23 AM
pattoncommander
Got it...now have the hatch open with latch & pad and a civilian test driver. Add the tow cable & once everything's dry, some touch up.
Still have a bit of file work on the hatch edges, but easy to get at and the upper chassis does not need any screws.
ID:	1783217   Click image for larger version
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
