Disable track recoil when using the K button on the remote?
I have older HL RX18 boards in my tanks and IR, and the IR system fires when pressing the K button on the remote. I would like to disable the track recoil when pressing the K button. I have seen a lot of mods including using two RX18 boards, tried that but still recoil.....
There may be a tiny switch on the main board to turn track recoil off , should be right next to the 8 pin plug. |
There may be a tiny switch on the main board to turn track recoil off , should be right next to the 8 pin plug. Need to use a tooth pick to flip it off. |
