RCU Forums
-   War Room (https://www.rcuniverse.com/forum/war-room-459/)
-   -   No two HL's are ever the same! (https://www.rcuniverse.com/forum/war-room-459/6879851-no-two-hls-ever-same.html)
gcadez 01-09-2008 12:53 PM
It's funny, I got 5 HL tigers and all of them seem a bit different all the time. One is fast, other slow, one turn hard to the right and the other slow. One shots 15 feet and the other 2 feet. One tiger on a test shot, blew a hole in the drywall? It would be nice if things were consistant. I am now filtering out the ones that perform the best and will use them for BB battles.
Fireman Tim 01-09-2008 01:00 PM
RE: No two HL's are ever the same!
Do you break your tanks gears in? It might help with speed.
wackywheelz 01-10-2008 12:55 AM
Yes, the tolerances in a non-broken-in metal gearbox can vary greatly, also things like bent motor mount etc cause un-needed friction.
borealis 01-10-2008 03:03 AM
On my Pershing I put both tracks side by side, and one was 5 mm longer than the other. When mounting them you could feel the difference in track tension. That could also be a cause for a tank slowly turning right or left while running.
I will rearrange the track sections until I'll have the same lenght for both.
