Timers and virtual switches
I am just getting to grips with my new BAT64, can't work out timers though. I want a flight timer operated by a momentary switch to flick to start and stop with Tx shut down to reset. I can't work out how to do it. I also want a switch on the throttle switch to turn on a timer so I can fly based on electric motor run time on, this is proving difficult too as I can't fully get into the logic for this. Norman Carter
I am geting there. Throttle timer sorted using f(x) switch but no luck on the momentary switch for start/stop/reset. Have it currently on a 3 position switch. Not been able to sort out a timer seset on Tx shutdown. Norman Carter
