Weatronic Clever?
Has anybody seen or heard of the new 6ch Weatronic Clever Rx? Is it small enough to be suitable for foamies (38"ws, 12-14oz size)? I'm expecting my 14MZ module and Rx very soon and would like to fly foamies with this system.
RE: Weatronic Clever?
I saw it at Jetpower. I believe they will work for you. Dimensions as per German website:
Abmessungen: 46,2 x24,1 x 13,1 mm Gewicht: 9 g |
Hi Jens,
I have one of the Clever receivers, they can easily be mounted on a foamy, the one I have is for a small depron indoor model You can even take it out of it's plastic housing, and save a few grams.. |
Hi Jens,
I have one, installed in a Me109 from Kyosho Airium, it work perfect. Regards Elvio |
ORIGINAL: DKjens Has anybody seen or heard of the new 6ch Weatronic Clever Rx? Is it small enough to be suitable for foamies (38''ws, 12-14oz size)? I'm expecting my 14MZ module and Rx very soon and would like to fly foamies with this system. I just got in the first package of two. I have the first smart receivers here. I will be taking pictures and putting them up on my website. Thanks, Gerhard |
Is the Clever 6 a full range RX? Hope so - ordered one for a Sebart Wind S 50!
The spec sheet shows 1500m so should be OK unless you have telescopic vision..... have not put mine in a plane yet so no direct exprience.
Regards Norman Carter |
Hi Jens, as you can see here, my son flies the clever 6 in his indoor yak, weight RTF is 150grams. http://www.youtube.com/watch?v=NpMxliUirfs The clever weights 6.5g using shrink tube instead of the reversible case. If you need it 2 grams leighter, there will be the TINY5 soon. Check WEAs website www.weatronic.com, there is a picture of it. It will be available end of this month. But Alwin states that the TINY5 is only certified and intended for indoor use, ie range up to 200 meters. It has on-board antennas but is still full programmable and can do telemetry as the big brothers do. best regards Thomas |
